![]() Join Date: Jul 2000
Brake issue
I've had this 1969 C10 forever, but I just recently noticed that the brakes take more pedal pressure than usual to stop the truck. Also, even if I stand on the brakes with 100% effort, they will not lock-up. However, the pedal does not go to the floor, nor does pumping the brakes help.
It has 1985 C10 brakes on the front with fairly new Wagner pads. On the back are 11"x2" finned drums (71-72 as I recall) with unknown shoes. Master cylinder has a 1-1/8" bore, and the combo valve is aftermarket. More info: I bled the brakes a couple years ago when I replaced the combo valve. Ended up with new clean fluid. I think the problem I'm having just recently started. Had a friend suggest a 1" master cylinder, but it's always worked fine with the 1-1/8". Any other ideas? Edit: I just remembered that I got the brake pedal about 1-1/4" closer to the floor by shortening the pushrod by a few turns. Did that a few months ago, but I don't recall having the problem then. But then again...
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-05-2025 at 03:46 PM. |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: Brake issue
Is it power brakes?
![]() Join Date: Jul 2007
Re: Brake issue
Any driving lately that caused heavy use of the brakes that may have glazed the pads or lining? Towing a trailer that doesn't have brakes, steep grades, lots of stops in traffic?
I'd also check the rear brake for a wheel seal leak as brake lining with gear oil on it or other contaminant can require a lot more pedal pressure. The 77 F2fiddy I have needs rear brake shoes and axle seals when I feel like tearing into it.
Re: Brake issue
Yes, power brakes with OE-type 11" booster.
No towing or carrying heavy loads.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: Brake issue
I'd check the booster vacuum source, check valve and whether it holds vacuum once the source is removed. If you suspect glazing or other pad/rotor mating issue, perform a fresh pad bedding and rotor seasoning procedure on a safe stretch of road...see if that changes anything. That procedure is documented Online but it's basically... Season Rotors: 1)heat the rotors to crazy high temp and let them cool all the way down...twice over the course of a couple days. This involves light stops followed by medium stops, followed by heavy stops then cool down then do it again harder the next day. Bed PAds 2) Heat up the rotors again with some medium stops, then perform maximum braking from 70 down to 5 without locking up twice in a row. Let cool for 10 minutes while driving. Do a few light to medium stops to put some heat into the system then perform 8 maximum brake events from 70 to 5 without locking up all in a row...then let it cool with 10-20 minutes of driving without using brakes. 1) above heat cycles the new rotor to make it resistant to future warping due to hard braking events or prolonged braking events. This procedure should precede pad bedding. 2) above beds pad material into the surface of the rotor for better braking performance going forward. It's common for the rotor to take a blue hue after this procedure and it's likely you'll smell the familiar brake pad burning aroma. Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Re: Brake issue
Check your rubber hoses. The inside liner can delaminate and block flow. Also if you ran low on fluid or had a little air in your system and hit the brakes hard you may have tripped your valve in the proportioning valve and need to re set that.
Re: Brake issue
Thanks, guys. I'll look at the easiest things first.
I'll check out the valve. The dash light isn't hooked up (shame on me), but I'll use an ohmmeter. Front brake hoses are only a couple years old, but I can't remember how old the rear one is. Hate to get into the bedding and seasoning. It would be hard to find a stretch of road where I could do a 70 to 5 stop! Did that a few times over the years with new pads, but not quite to that extreme.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-06-2025 at 11:11 AM. |
Re: Brake issue
OK. Looks like it's the booster that I had rebuilt in the mid-90s. Could not draw a vacuum on it with my lungs or my MityVac. Idle speed goes up when the hose is connected, just like with the usual culprit -- a cracked hose. The check valve seals fine.
Also pressurized it with 10psi air, and I could hear the leak out the back somewhere. Guess I'll go shopping for a new booster
![]() Join Date: May 2006
Re: Brake issue
I’ve got a new one laying here, if interested
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Jun 2022
Re: Brake issue
Bad booster will increase effort, but not prevent lockup, so there's at least one additional problem that may have been masked until the booster gave out
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#11 | |
Re: Brake issue
aros44sr--Thanks, but I already ordered one.
Re: Brake issue
Got my re-man booster installed. Haven't taken the truck out for a drive yet because the passenger door is all apart, but did back it out the driveway and drove it back into the shop. The pedal feel is totally different now. Better than ever. I suspect the old booster had a small crack in the diaphragm that grew over the years. So I've probably been driving around for who knows how long with a leak!
This retainer clip and wave washer were a bear to install! Actually that's a "before" photo. I got the clip back in with a flat washer, but not the wave washer. Not sure if I'm flirting with disaster, but I will get that wave washer installed some day soon. Also looking to use a shoulder bolt if I can find one with the right dimensions.
| Bookmarks |
