AC condenser rubber insulators
Are the rubber insulators for the ac condenser available any where?
I have searched on the net but found nothing. |
Re: AC condenser rubber insulators
Yes, these are what I bought a while ago.
https://www.ebay.com/itm/27145489155...EAAOSwRR5lgG98 But holy cow, they have gotten much more expensive. If the link doesn't work, search Ebay for condenser mounting stud rubber isolator. "thepartsplace" has them. I believe that a rubber nutsert would also work instead. Last edited by 72malibu; 08-09-2025 at 07:26 AM. |
They come with a new condenser
What im looking for is the original typ. bent sheet metal with rubber inserts.
Has any body seen them?
Do you have a picture? I honestly have no idea what version you are talking about. I've only seen rubber nutserts and the type with studs on both ends.
I dont know that I have a way to post pictures.
pictures
Oh interesting. I've not seen those before. My dad owned his '75 since '76 and those weren't on it. Must be a later model thing.
Looks like the same thing here: https://www.gm***************/thread...sulator.36368/ |
My guess would be they started in 81 with the front end change.
#11 | |
I have all the pieces its just the rubber has seen better days.
#13 |
52480249 and 52480250 ?
15956322 and 15956553 ? Not sure, maybe check the parts book for the correct numbers and try googling those. Or if your old ones have legible numbers. There are some ebay listings with some of these numbers. |
#14 |
You got closer than i did. The numbers on mine were hiden under undercoat.
#526182 for the rubber. Down the page. https://coronachrome.com/ols/product...-number-371922 |
#15 |
Not cheap but available.
#16 |
Thanks for the help.
| Bookmarks |
