Active Member
![]() Join Date: Aug 2022
60-62 auto trans xmember
was surfing simple c10 and see they offer one of these, not sure if its for long or short bed..
![]() Join Date: Feb 2011
Re: 60-62 auto trans xmember
Thanks for posting that and here is more information.
https://simplec10.myshopify.com/prod...on-crossmember Looks like they have for both longbed and shortbed and different transmission applications; This automatic transmission crossmember closely matches the original factory part. It bolts onto the X-member using the two factory holes on each side in the standard position. There is also a top center hole on both sides that can be drilled out, just like in the original installation. We have options to fit a 700R4/4L60E or TH350/Powerglide transmission with the engine in its factory location. Crossmembers ship direct from vendor, not Simple.C10.
MusicMan70 1961 GMC Suburban |
Finally. Man I wish I had one of these a long time ago.
| Bookmarks |
