Ignition switch- ACC powers points?
I’m wiring my fuel pump and ignition box. I figured the yellow wire to the coil would be hot only in the start and run positions, but it’s on in the acc position also. Is my switch bad?
Pat - Pat's Car Stuff - 68 Camaro RS - 68 C10 Shortbed |
![]() Join Date: Jun 2005
Re: Ignition switch- ACC powers points?
No, there should be no power to the points in the "ACC" position. If so, then someone has messed with the wiring.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Thanks!!
When doing electrical work, especially when adding electrical accessories, your best friend and tool is a wiring diagram.. These diagrams are available as download stickies in the ELECTRICAL forum..
![]() Join Date: Jul 2007
These two connectors in the fuse block are hot when the ignition is on only pins. I have my hei plugged into one of them on my 71.
I did that rather than deal with the resistor wire and bypass wire that were part of the points setup. I just taped the stock ign wire up and tied it up to the wirring harness so I could quickly and easily stick a point style distributor back in if I ever wanted to.
Keeping the points wire is a great idea, but all that is really needed is to replace the resistance wire on the engine side of the firewall with a 12 gauge wire to power the HEI. You could always remove the 12 gauge wire and reinstall the resistance wire if you wanted to switch back to points.
| Bookmarks |
