Old 08-15-2025, 01:43 PM   #1
cag
Active Member
62 gmc cab trim removal???
how do i get the trim pieces off the cab around the door without screwing them up??
cag is offline   Reply With Quote
Old 08-20-2025, 09:12 AM   #2
cag
Active Member
Re: 62 gmc cab trim removal???
anyone??
Old 08-20-2025, 09:56 PM   #3
DPowers
DPowers's Avatar
On the door trim across the top the trim is bolted on in a couple of places. This is on the top only. The rest of the trim is held on by spring clips. Take a plastic trim removal tool and pry them off gently. You can call me at 423 736 0421 if need to. The Custom Badges are held on by barrel clips. You can gently pry those off as well.
DPowers is online now   Reply With Quote
Old 08-21-2025, 07:26 AM   #4
cag
Active Member
Originally Posted by dpowers View Post
on the door trim across the top the trim is bolted on in a couple of places. This is on the top only. The rest of the trim is held on by spring clips. Take a plastic trim removal tool and pry them off gently. You can call me at 423 736 0421 if need to. The custom badges are held on by barrel clips. You can gently pry those off as well.
thanks!!
