U bolts for trailing arms.
My ubolts are 5/8" diameter. When I see the lowering block kits, it looks like they are only 7/16 or 1/2". Is that strong enough?
1948 Chevy 1/2T 1964 Chevy 1/2T stepside short bed 1939 Pontiac coupe Street Rod 2005 GMC 1/2T short bed |
Re: U bolts for trailing arms.
You are only using one bolt per trailing arm - stick with the 5/8".
I had a local 4x4 shop bend up a pair in the length I wanted for my '61.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Speedway has various length u-bots for 3" axle tubes. I just found the length I needed after installing 2" lowering blocks made out of thick walled square tubing from an old weight set based on a write up in the FAQ section by the TX Firefighter. I believe the u-bolts I got were 3/4. I would say 5/8 should be fine, but I wouldn't go any smaller personally.
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
![]() Join Date: Dec 2009
There is also this place in the link below .
Link: https://uboltstore.com/?msclkid=9416...16bc510efa36f1
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
| Bookmarks |
