ls alt output
Thinking of upgrading my stock factory alt . My LS1 is out of a 2002 Trans am. When I turn on my ac the vots drop to a level I am not comfortable, only at idle . once in motion all good. I think factory is 102. In that case I am looking for a 110 upgrade. Thoughts
![]() Join Date: Sep 2005
Re: ls alt output
need to make sure that when ac comes on that he pcm bumps the rpms up likw 250 rpms and that will solve your low voltage issue
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
Re: ls alt output
I am not smart enough to do that. My experience with taking my truck somewhere for repair has been horrible. It is running so well I hate to have someone tell me they can fix it and screw up things (as in the past) and never fix my problem. I remember when I installed my harness (oem rebuilt) there where 2 wires I didn't hook up that were marked TCC and Tach. What is the TCC? I know what the tach is,
Re: ls alt output
I may be totally off base but is the TCC Torque Converter Control connection? Controlled by the ECM TC lock up wise.
![]() Join Date: Nov 2013
Re: ls alt output
My LS1 is also out of a 2002 TransAm
I put a 140 amp alternator on it and I just a few days ago, bumped up the base idle settings by 75 RPMs That made a difference in the idle when the AC compressor kicks on. I'm looking at wiring it so the PCM will sense the compressor and bump it another 50-75 RPMs I'm not sure about voltage drop because I haven't actually monitored it on the scanner. I'll take a look next time I'm under the hood.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
Re: ls alt output
Thanks for the TCC info. Everything in trans works great so I am not going to mess with it.
Keep me posted on how you plan on bumping up the pcm function. I look forward to following this update. Thanks |
#7 | |
Re: ls alt output
Re: ls alt output
Not a new problem. Been this way since I had my ac put into service.
I just avoid turning it on unless I am on the highway. The truck has no issues with charging with the lights on at idle. I may need to change out cooling fans as the ones in there Ipulled from some dodge suv I bought at pick your parts and they me just be drawing to many amps. |
| Bookmarks |
