Old 08-18-2025, 01:33 AM   #1
BigRandy
BigRandy's Avatar
Cloyes C-3023X Timing Set 3 degrees advanced?
I have 112,000 miles on a stock 74 454 in my C10 and I'm going to replace the timing set soon before it jumps. A friend suggested using the Cloyes C-3023X double roller with adjustable crank gear and install it 3 degrees advanced.
He said the engine was detuned by GM to meet certain standards, and that using the crank gear to advance it would result in more vacuum, better idle, and better midrange torque.
I have a hard time believing it's possible to get something good for free, and I don't want to do this twice. Is his info correct?
Repairing and driving old trucks is an analog experience. They have no computers or sensors and can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
Old 08-18-2025, 08:13 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Cloyes C-3023X Timing Set 3 degrees advanced?
C-3023X set comes standard with +2, 0, or -2 keyways slots.
Go with +2,,,however...
If the chain and gear set is so worn you expect it to jump time, what is the rest of the engine internal like?
Over to you...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-19-2025, 01:35 AM   #3
BigRandy
BigRandy's Avatar
Over to you...
Great question. I'm not 100% sure.
However, this is more of a PM based on my experience with engines using nylon gears. The engine seems fine. It has good compression, 45+ psi oil pressure on a hot highway and 32 at idle. It uses a quart about every 1000 miles, same as my 73 - 454 with 80K. I'm guessing it's in good shape. It's not a hotrod. Just a daily driver when I can afford the $&%@#! gas.
Old 08-19-2025, 01:36 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Just wanted to make sure you dont open Pandoras box....
If the original cam gear is one of those plastic fantastic wonders of modern design madness, then you may be good...just ensure any worn out pieces are not sucked into the oil pick up screen.
Old man signing off now
2025 Chevy Equinox
Old 08-20-2025, 09:17 AM   #5
THI
THI's Avatar
Decades ago I had a 1972 Kingswood with a Small Block 400 with 70,000 miles on it when the timing chain jumped one tooth. That is when I discovered that GM was using aluminum/plastic timing gears on the cam, the only problem was the plastic was all in small pieces in the bottom of the oil pan! Cleaned it all out, installed a standard Cloyes link belt timing set and the car ran great for another 70,000 when I sold it. The standard Cloyes link belt timing set held up much better than the original.
THI is offline   Reply With Quote
Old 08-20-2025, 02:44 PM   #6
BigRandy
BigRandy's Avatar
Thanks, guys. Can you tell me if the 2 degree advance is noticeable?
Old 08-20-2025, 08:23 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
Seat of the pants...yes, better than 0....much depends on rest of engine condition...
Headers will wake it up and if you are looking for more.
Make sure the distributor is scoped out and providing you the advance it neads.
2025 Chevy Equinox
Old 08-20-2025, 08:25 PM   #8
AussieinNC
Moderator
AussieinNC's Avatar
MMM...now back in Australia I had a 1972 Kingswood (Holden) with a 308 and auto trans...went well and was reliable....brings back some good memories.
2025 Chevy Equinox
Old 08-20-2025, 08:48 PM   #9
twinsemi
twinsemi's Avatar
Two degrees is not going to make a huge difference.
It will give you better low end torque, better idle and a lower top end RPM limit. On the Comp Cams 265 in my 283 SBC, it is set to +4 deg and it drops the HP peak from 5900 rpm down to 5600.
twinsemi is offline   Reply With Quote
454, cam, cloyes, timing
