Active Member
![]() Join Date: Oct 2023
Hello all, unable to work on it, torn rotor cuff, looking at months to recover from surgery,
Sent it to local shop, here are the problems so far, all Classic Industries parts New Gastank in ,New grommet doesn't fit ,grommets don't even look the same, new gas cap loose on New tank,is there difference between C10 C20 gas tank grommet? New Tilt column for 700R4, park and low on column indicator not in correct positions, tranny working, do I need ,or is there a different, longer shifter rod from from column to tranny ?have all gear positioned, neutral safety works in Park n neutral, just doesn't have full travel range from Park to Low, rod clamped at very end Factory seat out ,ragged but foam and springs intact, shop says if I buy hog ring pliers and kit they will fix seat w New seat cover Factory / dealer install under dash A/C missing compressor , all other components intact, Which aftermarket A/C should I go with. So many questions and I can't work on it ,looked at truck this am and the shop is stopped working due to these issues. Seeking wisdom , knowledge and help. Any and all input welcomed Thanks, good luck on all your projects
70 C 20 Longhorn PS , PDB, Dealer installed AC, 700 R4, Dual battery, original TAX 350 motor, 3rd owner truck. 71 C 50 292 4sp 2sp vacuum operated rear end 8 x 12 flat bed. 22.5 Goodyear radial$ n Wheels Now rim$ 86 Grand Wagoneer " Saggy Waggy " Jeep = Just Empty Every Pocket $$$ currently in another shop |
![]() Join Date: Jul 2007
Re: C 20 Longhorn project problems
The Filling Station https://www.fillingstation.com/ Shows one gromet for 67/70 and a different one for 71/72. They are usually spot on on what fits what Chevrolet wise in their catalogs.
I looked up Classic industies and what they show for 69/72 is what the Filling station shows for 71/72. I think I have ordered one item from them in the past 20 years simply because they listed it and some of the others didn't but thay are not my go to truck trinket vendor by any stretch. Gas cap I'd just get at the local Napa and make sure that it is a vented cap. The one shown here is listed as being for your 70 C 20 and being vented. Take care with that rotary cuff and do every bit of the rehab they give you and do it at home. Then don't lift or pull too much until well after you know that you are healed up. I had it a year and a half ago and may have to have the other shoulder fixed now.
![]() ![]() Join Date: Jan 2005
Lokar makes shifter linkage kits where the attachment point at the transmission end can be adjusted to change the ratio.
Lokar ACA-1811 |
#4 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Looking at Lokars site no length given on the 1800 but the 1811 shows a 26 inch rod. For me the Lokar was an after thought as without it I couldn't go right to 1 on the selector.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
Active Member
Wow on the Lokar thing, will get one on the way . Ordered NOS grommet from member here
Classic bowties, spent almost hour on the phone with him today , really outstanding customer service, great source of knowledge and information, on to truck issues Replacing radio with Hermosa Retro Sound, be here Thursday, should I put a new in dash speaker in or just rely on Bluetooth speaker only, that didn't come out right, don't know about Bluetooth thing at all , shop owner ask me this today ? inner glove box and radio are out, doing heater box/ core/blower motor at same time , is now the time to replace dashpad? It looks good , just loose on dash . Good thing shop doing work has race car and racing on Friday, gives me a week to plan ahead for next operation. Any a d all input on what next steps should be? Can't work on it myself. Thanks to all who replied. Good luck on all your projects
| Bookmarks |
