Old 08-18-2025, 05:26 PM   #1
darguy
darguy's Avatar
93 K20: ECM & Tranny Wiring Questions
I've got a 1993 K20 chassis and drivetrain underneath a 72 body - I bought the truck as an incomplete project. I'm cleaning up the wiring and installing a Dakota Digital dash and assorted DD modules. 5.7L TBI and 4spd electronic tranny with a manual transfer case.
I have a couple lingering questions about what may have been hacked out or left unplugged by the PO, and what additional ECM inputs I'm going to need to make it run properly.
There is a single green wire/connector that looks like it would have been for a coolant temp warning light - the CTS and wiring is intact. I'm assuming I can just delete this wire as I'm using the DD dash.
In the same bundle of wires near the thermostat is a brown wire that's been cut - not sure what that was for.
And, should there be a purge solenoid? The way I got it, the canister is direct to the TBI base.
Cheers
'72 K-20 Frankentruck
'68 Beaumont Wagon
'05 Chevy G2500 Camper "Tiki Van"
'22 Honda CB500X Island-Hopper
darguy is offline   Reply With Quote
Old 08-22-2025, 11:05 AM   #2
Second Series
Second Series's Avatar
Re: 93 K20: ECM & Tranny Wiring Questions
That is a cool truck. The wiring diagram is available on this site, in this forum, in the FAQ post. here is a link to the thread https://67-72chevytrucks.com/vboard/...d.php?t=700011 I looked at it briefly but 307 pages will take some time to find the one or two you need.
I had to look up purge solenoid... I have an '88 and '90 truck. The charcoal cannister has a line to the fuel tank and a line to the TBI base, no purge solenoid on those years.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
