Old 08-23-2025, 09:57 PM   #1
kna4977
Evaporator Core Access and Cleaning
1972 factory A/C. Can't seem to get my system to cool like it should. No leaks, everything is clean, lots of new parts. Only thing I haven't done so far is inspect/clean/replace the evaporator core. Can it be cleaned without removing the box that contains it under the hood on the passenger side? If so, how?
kna4977 is offline   Reply With Quote
Old 08-24-2025, 01:45 AM   #2
Hidesertchevy
Re: Evaporator Core Access and Cleaning
Cleaning the evaporator requires removing the box under the hood.
Hidesertchevy is offline   Reply With Quote
Old 08-24-2025, 03:05 AM   #3
Richard
Removing fender liner makes removal easier. 50+ years old. Maybe worth a look at it.
Richard
Old 08-24-2025, 04:41 PM   #4
kna4977
Could you not leave the box attached and the inner fender in place and just remove the inner side of the box to inspect and clean the core?
Old 08-26-2025, 10:02 PM   #5
kna4977
This is why I ask if it's possible and if anyone on here has tried and done it successfully. Truck in the video looks to be 73 or later. I'm thinking a 75 or so. It has a little different setup and some different A/C components. The video is titled 67-87. Before I attempt it, can anyone confirm if this will work on a 67-72?
https://youtu.be/M4hGULHGo6U?si=9Z559ocu_Aq_wgdD
Old 08-26-2025, 10:21 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Worth a try if depressurized I guess. Wow the sludge on that core, I've never seen that, though who knows how long my system wasn't running.
If you think the gaskets will be compromised, especially on the firewall, I'd do what Richard said, and then pull it off. May as well address the heater core while you're at it, if due, sure hate to do that back to back☺
If you're running R134A with a basically original system, it's not going to cool like R12.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-27-2025, 01:55 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 71chevyshortbed402 View Post
if you're running r134a with a basically original system, it's not going to cool like r12.
this 100% ^^^
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-27-2025, 09:15 PM   #8
kna4977
Originally Posted by leddzepp View Post
this 100% ^^^
I've read that too, but why not if the POA is calibrated correctly? I've done other R12 systems to R134 and they are r12 equivalent ice cold, but they do have different components. Orifice tube and accumulator vs the POA and expansion valve on this system.
Old 08-27-2025, 09:56 PM   #9
Rick Bollinger
I did mine 100% stock except compressor that's a Sandan. Completely cleaned everything adjusted POA, 134 no problems except some noise. Just be ready to replace your blend door in the box. My new one took some trimming to get it to seal correctly. O rings are cheap, door not to bad either. Cools just fine.
Rick Bollinger is offline   Reply With Quote
