Before and After
U - Bolt Measuring
How do you measure a u-bolt for the rear axle?
Inside or Center to center? Where do you measure the length to? Inside of radius or just the straight part? I can figure out the diameter. Could someone give an example of how it would be written.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Formerly yellow72custom
The diamater would from inside to inside of the 2 shanks. It is 3-1/2" IIRC. For a 12-bolt anyway.
Just take the old U-bolt with you when you go buy new ones. You will be sure to get the correct one that way.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
