Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Trucks For Sale
Old 08-24-2025, 08:39 PM   #1
Utahboy
72 C2500 GMC Sierre Grande
SOLD Locally
Hate to do it, but its time to let this go. Very original 1972 C2500 Sierra Grande Custom Camper. Has the original 402 motor and 400 trans.
I bought this truck 8 years ago in Southern Idaho and had it shipped to Michigan. It has never been driven in the Winters here nor in the rain. Always stored indoors. I have added a few factory options that it didn't have but kept everything else as it came from the factory.
Added - Tilt column, Factory AM/FM Radio and Tach dash.
All original Sheet metal, no rust through
Original paint and patina
Original rockers
I properly repaired both lower cab corners (only place where rust existed)
All original side moldings
The truck is very solid and straight with a few small bumps on it.
This truck has been properly maintained. Previous owner stated that the engine and trans were rebuilt (to factory specs). When I pulled the motor to re-seal it. the rod caps were numbered stamped and everything was super clean inside.
The only thing that does not work is the A/C. All A/C components are there and the compressor will turn, but there is no freon in the system.
This truck does not have a rattle or squeak. It runs and drives as it should.
Tires are new (on 16" wheels)
New window regulators
All new drive shaft u-joints and carrier bearing
Added Pertronix pointless ignition
Rebuilt original carb
New Belts and hoses
New 4 core radiator
New carpet and matching floor mats
I have matching new seat upholstery from PUI still in the box that goes with.
New chrome bumpers (Still have original rear step bumper)
New Brakes
I replaced all the front end grease zerks.
I could go on, but I'll stop here. If you are looking for an original unmolested C2500 you should seriously consider this one. Thanks for looking.
Asking $13,500
Utahboy is offline   Reply With Quote
