Old 08-27-2025, 07:52 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Parts Lot, Primarily 1971-ish Truck Stuff
Everything here is sold, even if it doesn't read so. The only exceptions are the jack assembly, and the rear license plate lamp. I'll put those on a new thread. Thanks a bunch.
NOS Stuff
NOS rear license plate lamp, $75
NOS Outer roll-up window sweeps, $150 SOLD
NOS Vent Window Channels, for the roll up window's front. I can unwrap them for a picture if you like. I've seen them before, they're perfect, including the chrome strips. Maybe you've seen these before, they're basically GM replacements. The tops aren't quite like original but they work. They do not come with brackets to mount it to the doors, nor the holes for the brackets, they'll have to be drilled, $125. SOLD
NOS interior door handles, $100 SOLD
NOS replacement rear lenses. These have some of the same markings as GUIDEX lenses, the appearance too, and they're at least as heavy as original. These are better quality than today’s replacements, and are very clean, $20.
NOS hose breather Assm., 10118694, probably not for trucks - if you recognize it $2, I think the old pinch clamps are worth that☺
NOS crankcase hose pipe, PCV, adapter, 3856955. Looks like some 66-67s take it, for example, $5
NOS crankcase fire arrestor. I don’t know the application short the fittings are BIG, $25. Nice score if a guy needs it. Okay, $20, no, $15☺, no, $8.
NOS emblem paint syringes - apparently. I'll just keep them.
NOS vintage radiator hose clamps for couldn’t tell you. If you like them $5. Let me know if you need measurements, they're pretty cool.
OEM Stuff
OEM lug jack, handle and lug wrench. Works, the metal excellent and real nice finish $120.
Two nice C10 hub caps. One never painted and the stainless is perfect. The other was painted and polished, but has a few small dings that are an easy fix, described the arrows in the image. Can’t imagine why someone painted and polished it so nice, dings included. These are not a matching pair, while it's not easy to distinguish, GM installed many varieties of these stainless caps, the differences are primarily at the ring surrounding the bow tie, and weights can vary too. Asking $70 each. SOLD
OEM truck tie downs, they’re in excellent shape and will clean-up super if you care to, the finishes are perfect either way. I don’t know what they’re worth, but if someone is looking for these, I think $25 would be a deal. SOLD
One NOS Deluxe Badge with some pitting. The other is used, but the chrome is beautiful, $10 for both.
Two OEM 400 badges. One has excellent chrome, the other is okay, and was used to experiment with a black epoxy finish. FWW, it held up remarkably under test conditions, $5
OEM oil cap, I think so anyway, hmm. Buy something else it's free.
OEM Grille brackets, for a 1971-72, perhaps earlier too, I don’t know. $40 SOLD
OEM tail housings, nice shape, $25 SOLD
One fuel cap, I believe it's OEM, for an auillary tank, needs a new gasket - buy something it's free.
One OEM spare tire bolt and wing nut. It's OEM, but I don't know the application, $10, wing-nut is worth that easy, hmm, maybe I'll keep it☺ Called for☺
Couple of OEM bed towers, buy something it's free.
OEM washer bottle bracket, $10 SOLD
Nice pliable and clean OEM brake pad: $3 I'll just keep it.
Some vacuum fitting, if you recognize it - free if you're paying shipping. called for
OEM points distributor and parts. It came off a 1971 402/400. The distributor (1112064-0M7) basically failed back in the 90s, I switched to HEI. I don’t know why the distributor failed, someone else was doing the work. If you want these parts just pay shipping. CALLED FOR
Replacement Stuff
New replacement sport bumper bolts and hardware. Somewhat replacement, the fronts are supposed to have smaller heads, what can you do, I suspect the fronts aren't reproduced. $8
New replacement bed bolts with hardware, $15 SOLD
New replacement 5/16-18 Rally cap bolts, 20 of them, $7
New brake boot, free if you buy something. I'll just keep it.
New blower gasket at the firewall. I'll just keep it.
New replacement fuel sender for without a return line. Part number 72-9300-S, $20 is half the price otherwise available on this part.
New replacement heater water hose tower clamps, $5
New correct type replacement thermostat housing, since painted with POR15 engine. Sprayed if I remember right, turned out pretty nice. I ended up with three of them somehow☺ Spray isn't as durable as a brush with por-15 engine FWW, which applies nicely on cast iron. Looking forward to painting the original housing I thought I wasn't using SOLD
Buy something for $15 more I'll put a copy of the kit into the box. It's described by my signature.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-27-2025, 07:56 PM   #2
71CHEVYSHORTBED402
Re: Parts Lot, Primarily 1971-ish Truck Stuff
More OEM stuff
Old 08-27-2025, 07:57 PM   #3
71CHEVYSHORTBED402
Replacement stuff
Old 08-27-2025, 08:08 PM   #4
jimer1964
jimer1964's Avatar
I will get in line for the hub caps if you will separate , Also interested in the thermostat housing Thank you
jimer1964 is offline   Reply With Quote
Old 08-27-2025, 08:43 PM   #5
Louisvillekytruck
I will take the washer bottle bracket and tail light housings and bed bolts. Let me know how much and how to pay thanks 40291
Louisvillekytruck is offline   Reply With Quote
Old 08-27-2025, 08:48 PM   #6
71CHEVYSHORTBED402
Looks like I'm separating. I see I didn't put a price on the housing, ooops. We'll make it work, thank you. $150 sound good before shipping?
Here are better pictures of the blue cap showing the flaws mentioned. The original picture was unclear. FWW, the blue cap's design is the nicest I've seen, lots of bling, and it's heavy too.
I'll respond to each post in this thread as a place holder. I have to get boxes, some packing material and shipping quotes yet, the caps for instance will be insured. I won't have access to the parts for 12 days, at that point I'll prepare shipping and PM the amt., and we can figure out payment methods then. That said, I'm going to pack the caps and housing tomorrow, edit, I've already packed it, pending zip code. It will go a long way if buyers are willing to post their zip codes with their deals, so I'm prepared, thanks. Still open to deals on volume.
Old 08-27-2025, 09:16 PM   #7
71CHEVYSHORTBED402
I'll respond to each post in this thread as a place holder. I have to get boxes, some packing material and shipping quotes yet. I won't have access to the parts for 12 days, at that point I'll prepare shipping and PM the amt., and we can figure out payment methods then. That said, I'm going to pack your parts tomorrow, perhaps a medium flat rate will do. How's $40 sound, before shipping?
It will go a long way if buyers are willing to post their zip codes with their deals, so I'm prepared. Thank you.
Old 08-27-2025, 09:24 PM   #8
Louisvillekytruck
Sounds great . How much more for the grille brackets
Old 08-27-2025, 10:10 PM   #9
71CHEVYSHORTBED402
Think I have to get $35 as opposed the asking of $40, the box will run me another $5 or so. Let me know, and what your zip is at some point, so I can get a shipping quote, thank you
Old 08-27-2025, 10:23 PM   #10
Louisvillekytruck
I will take them 40291 thanks again
Old 08-27-2025, 10:50 PM   #11
71CHEVYSHORTBED402
Cool, thanks. I'll pack tomorrow and send a quote too.
Old 08-28-2025, 08:37 AM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Ill take these: NOS interior door handles, $100
**Sold - payment sent
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-07-2025, 07:39 PM   #13
Dave
DND Trucks
Hi Tony,
What's the numbers on the distributor? Also, what are the numbers on the window sweeps?
Dave is offline   Reply With Quote
Old 09-07-2025, 08:18 PM   #14
Louisvillekytruck
Received parts everything looks great thanks tony
Old 09-08-2025, 12:17 AM   #15
72BBChuck
72BBChuck's Avatar
I will take the mystery vacuum fitting. How much to 98531? Thanks, Chuck
72BBChuck is offline   Reply With Quote
Old 09-08-2025, 05:47 PM   #16
71CHEVYSHORTBED402
Originally Posted by Dave View Post
Hi Tony,
Distributor 1112064-0M7
Sweeps: 3893783-4
Cool, thank you
$11, please do not pay with PAYPAL goods and services. PM with your address please, or if MO/check, I'll give you my address, thank you.
Old 09-08-2025, 06:15 PM   #17
71CHEVYSHORTBED402
Posts were addressed above, thanks.
More pictures of the Jack, handle and wrench, these are nice. Wrench is for a 13/16" nut. I dropped the price $20 to $130, edit $120. I buy the box. you pay shipping. USPS puts $100 insurance on packages these days, for "free".
Old 09-08-2025, 09:27 PM   #18
Dave
DND Trucks
I'll take the nos sweeps, distributor, coil and brkt. Lmk payment details when you can.
Thanks.
Old 09-10-2025, 11:37 AM   #19
71CHEVYSHORTBED402
Thanks.
Hi Dave, in case you missed the PM, what is your shipping zip code please?
Old 09-10-2025, 11:39 AM   #20
71CHEVYSHORTBED402
I dropped the prices on what's left over. If perhaps the OP wasn't originally clear, the buyer pays shipping.
Old 09-12-2025, 07:53 PM   #21
Dave
DND Trucks
Tony, PP has been sent. Thank you.
Old 09-15-2025, 10:32 AM   #22
71CHEVYSHORTBED402
Ooops, I just got the message, thank you Dave, appreciate that. I'll mail it tomorrow morning, insured $150.
Old 09-15-2025, 02:45 PM   #23
71CHEVYSHORTBED402
Prices dropped again. Pretty sure I'm 1/2 available price or better on everything - some free if you buy something, time to clear the table - package deals? Thanks..
Old 09-16-2025, 04:44 PM   #24
jimer1964
jimer1964's Avatar
Caps arrived safely! Very nice! Thank you!
Old 09-30-2025, 06:30 PM   #25
71CHEVYSHORTBED402
ttt
