Old 01-18-2004, 05:04 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Ride height valve bleeding
Does anybody know when GM started using the ride height valve in our trucks? Anyone know how to bleed the darn thing?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-18-2004, 05:11 PM   #2
TIMSPEED
TIMSPEED's Avatar
Re: Ride height valve bleeding
I assume you wanna go lower
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 01-19-2004, 09:36 AM   #3
RockHQ
ROCKET POWER!
RockHQ's Avatar
Gchemist, are you talking about a load sensing brake proportioning valve? if so, jack up the rear end from the point where the proportioning valve connecting lever attaches to the rear end so the valve will feel a full load and open up. That, or disconnect the lever and push it by hand to gain the same result.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 01-20-2004, 12:01 AM   #4
gchemist
gchemist's Avatar
Yea, them rookies aways think of something else.
Thanks. I'm tracing this info for another guy. I think this will help him bleed his brakes. I'll be sure to give you credit!!
Old 01-20-2004, 12:14 AM   #5
TIMSPEED
TIMSPEED's Avatar
Shoot, you shoulda said that to begin with...I didn't think of that because I thought you were talking about your truck...didn't they only use those load proportioning valves on 3/4 tons and Longbed's??
See Them Here
Old 01-20-2004, 12:42 PM   #6
KShortell
KShortell's Avatar
Yes, Tim. The guy he's looking to help has a 3/4-ton truck...
Semper Paratus
KShortell is offline   Reply With Quote
