Old 09-07-2025, 02:29 PM   #1
kna4977
A/C evaporator box shims which positions do they go?
Separated the a/c evaporator box and there were two shims that fell out before I saw where they went. Can someone please tell me where they go so
I put it back together correctly?
kna4977 is offline   Reply With Quote
Old 09-08-2025, 12:41 PM   #2
kna4977
Re: A/C evaporator box shims which positions do they go?
Anyone? I'm thinking they go on the front, but not sure and not sure if they go between the evaporator tabs and the section closest to the passenger fender or between the half that is on the other side and the evaporator.
Old 09-08-2025, 03:17 PM   #3
Richard
Sorry, do not have any idea what you are asking about? I do not recall any "shims" being used in my system. Can you post a picture of the parts? There are some backing plates that go inside the box where the TXV/POA bracket attaches.
Richard
Old 09-08-2025, 07:12 PM   #4
Rick Bollinger
Are you talking about the metal tubes that go between the firewall and a/c housing? If so the longer screws that are exposed on top they go there.
Rick Bollinger is offline   Reply With Quote
Old 09-08-2025, 07:51 PM   #5
kna4977
Here’s a pic of the shims. The box had never been apart so they have to be factory. I’m thinking that they went on the front middle two bolts but not sure if they were or if so how they were oriented.
Old 09-08-2025, 09:19 PM   #6
Richard
Those are body shims. Probably fell from the corner cowl bolt that is kind of above the box.
Richard
Old 09-08-2025, 10:27 PM   #7
PbFut
+1. No shims on my system either. They are likely body sims dropped and not recovered from as far back as originally assembly.
PbFut is offline   Reply With Quote
Old 09-09-2025, 12:50 AM   #8
Rick Bollinger
If you removed the inner fender there are shims that go behind the large bolt way under and in the back of your inner fenders. Between inner fender and cab.
Old 09-09-2025, 03:47 AM   #9
Richard
Yes, one or two may be found there on each side. The shims should look like this though https://classicparts.com/1967-72-fro...-f-shim-set-pr
Richard
Old 09-09-2025, 09:17 AM   #10
kna4977
None of that was touched by me. I'll reassemble the system without shims. Not sure where they came from originally or how long they were where they were. Thanks for the answers.
Old 09-09-2025, 09:24 AM   #11
mkmc69
mkmc69's Avatar
Probably spare parts from when it was assembled eons ago. Your truck was probably a Friday afternoon or a Monday morning built truck. Someone thought they were being funny and just threw them in the A/C box when the truck was going down the line.
mkmc69 is offline   Reply With Quote
Old 09-10-2025, 03:58 PM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I think inner fender are usually "F" shims, but though I suppose there could be varieties. Those look like common 3/8" OEM body shims from here and perhaps they fell like others say, graveyard shift and hammered, like when they installed my radiator, missed some rivets, too high on one Deluxe badge.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-10-2025, 05:59 PM   #13
Rick Bollinger
71 short you are correct originally they were F style shims. But I have never seen them in place. I'm guessing most don't get put back in.
Old 09-15-2025, 04:41 PM   #14
71CHEVYSHORTBED402
Glad to hear you say so. I can't remember if I bought them, but found no need to install them, and didn't find shims there to begin with. The inner is square on the rail, what more can you ask for. Perhaps they make it easier to install the parameter, not sure.
Old 09-21-2025, 08:31 AM   #15
GMCPaul
HereÂ’s a pic of the shims. The box had never been apart so they have to be factory. IÂ’m thinking that they went on the front middle two bolts but not sure if they were or if so how they were oriented.
Shims in photo are those used behind the 2 upper front fender bolts at top of front fender at cowl. So at some point the 2 top rear bolts at cowl were loosened or removed allowing these to fall out.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 09-22-2025, 11:34 AM   #16
kwmech
I've seen shims like that under the corner cowl bolt. Regardless, they don't belong inside the evap box
