Old 09-08-2025, 06:36 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
need help with bleeding brakes
i replaced both rear wheel cylinder on a 87r10 today along with new pads, the truck has been sitting for along time. i filled the master with fluid and cracked the bleeders and i am getting good fluid flow with gravity. after this i cranked it up and pumped and held pedal while opening the bleeders with a helper, and i got very little fluid and the pedal doesnt go down at all like it should.
is this a proportioning valve issue? ive heard of people resetting them but ive never had to do this and not sure how to go about it. a video i watched said if your not getting fluid to the rear to just pump and hold pedal and bleed the front 2-3 times and that should reset the valve, is that true or is it done some other way? thanks for the help
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
