Old 09-11-2025, 01:01 PM   #1
cag
Active Member
DOME LIGHT WIRES pull thru???
had a string pulled to fish wires thru, it broke in the process of getting the wires kinda thru, any ideas on fishing the wires with the clip thru???
cag is offline   Reply With Quote
Old 09-11-2025, 04:04 PM   #2
forestb
forestb's Avatar
Re: DOME LIGHT WIRES pull thru???
Thin wire that will bend easily and bend the tip slightly so that when you hit the one curve it will be prone to turn that corner. Snake it in pushing it in towards the drivers side. I have never tried it before. Just an idea.
You could also tie a string to a bolt and then use one of those grabber tools to go inside the hole and drop the bolt when you think it is above the turn down.
forestb is offline   Reply With Quote
Old 09-11-2025, 10:47 PM   #3
twoskies
twoskies's Avatar
piece of string with a nut tied to it, use a magnet with a microfiber to keep from scratching the paint, when you get to the corner pull the magnet, gravity drops the nut to the bottom
worked for me
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 09-11-2025, 11:37 PM   #4
forestb
forestb's Avatar
Magnets. I always forget about magnets
Old 09-12-2025, 01:23 AM   #5
Accelo
Accelo's Avatar
Cheap electrical fish tape works.
I have found lots of uses for it.
For instance, wiring trailers. Works excellently to get the wires through the square tubing frames.
$29 for a 50-footer on Amazon
Accelo is offline   Reply With Quote
Old 09-12-2025, 07:34 AM   #6
cag
Active Member
thanks yall!!
