Old 09-11-2025, 07:55 PM   #1
Brian 72 K20
Junior Member
72 K20 Front Axle U Bolts
I just realized the second set I got doesn't fit. The first was from tuff country and said they'd fit-no. The second was from LMC, I assumed they'd fit since all they sell is truck stuff-no such luck. Maybe there's a bunch of different sizes of u bolts on these trucks. The big one measures about 7 1/4 x 3 1/2 and the small ones about 6 3/16 x 2 3/4 (or 13/16). Dorman measures the width inside across and the length to the inside of the bend. I'm looking at Dorman 929-839 and 929-715 which are pretty close and I'm hoping just my measuring error.
Can anyone confirm or know ones that will work?
Brian 72 K20 is offline   Reply With Quote
Old 09-12-2025, 01:29 PM   #2
ohboy321
ohboy321's Avatar
Re: 72 K20 Front Axle U Bolts
I recently ran into this same problem when trying to use Skyjacker UC2F U-bolts. One vendor had listed them as being used on 67-87 K10,K20 trucks and they have a 2-3/4" I.D.
I was installing a 1978 D44 and the tubes on that measure 2.870". The tubes on the 1970 D44 I removed measure 2.750".
What I ended up using was Tuff Country 17701 U-Bolts that have a 3.0" I.D.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 09-12-2025, 01:31 PM   #3
71Farming
I went through the same headache trying to locate some ubolts for my 67 k20 with a closed knuckle front. Ended up using 2.75"x8" x5/8" (3) and 3.375" x 9" x 5/8" (1). I went longer length and cut to fit once final install was acceptable. Picked them up at a offroad shop in Auburn CA for around $47 out the door.
71Farming is offline   Reply With Quote
Old 09-12-2025, 03:26 PM   #4
Brian 72 K20
Junior Member
Thanks, it's crazy both sets I got said they fit the K20 and no where close when going thru the top plate. I might order the ones from Dorman and if they don't work salvage the ones I have. The threads are a little dinged up but I'll try cleaning up.
Old 09-12-2025, 03:43 PM   #5
Brian 72 K20
Junior Member
maybe I'm missing something. How'd you get the u boltsto thru the plates that sits on top of the spring if the id is narrower or wider? I would have to squeeze these tighter about 1/8 inch.
Old 09-12-2025, 09:36 PM   #6
70 gmc c2500
Junior Member
To the OP, you need to first identify your front axle and then make sure your top plates match the axle diameter then go from there. Give RuffStuff Specialties a call and he'll get you right. https://www.ruffstuffspecialties.com...BoCjscQAvD_BwE
70 gmc c2500 is offline   Reply With Quote
