Old 09-17-2025, 05:54 PM   #1
truckeroy
truckeroy's Avatar
Dropped shocks
Can someone explain to me if a stock shock has a collapsed dimension of 10 inches, how can an advertised lowered shock for a 3 to 4 inch drop have a collapsed dimension of 9 inches and not bottom out?
1948 Chevy 1/2T
1964 Chevy 1/2T stepside short bed
1939 Pontiac coupe Street Rod
2005 GMC 1/2T short bed
truckeroy is offline   Reply With Quote
Old 09-17-2025, 11:21 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Dropped shocks
The shock is on a different motion ratio than the spring, which is on a different motion ratio than the wheel.
Typically, on this suspension, a 3" drop at the wheel is actually 1.5" at the spring, and probably (but I have not measured) 1" at the shock.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 09-18-2025, 05:42 PM   #3
truckeroy
truckeroy's Avatar
Re: Dropped shocks
Thanks, that makes sense, but some of those dropped shocks have the same collapsed dimension as the stock ones.
1948 Chevy 1/2T
Old 09-18-2025, 08:01 PM   #4
SkinnyG
SkinnyG's Avatar
Re: Dropped shocks
Yes, I've noticed that too. I've seen "drop" shocks that are longer. Some people don't math well.
Old 09-19-2025, 02:51 PM   #5
SCOTI
SCOTI's Avatar
Re: Dropped shocks
This is exactly why I run stock length shocks & tweak the mounting bracket to suit. The factory shock travel is already limited so I don't like reducing it @ all.
In the case of a C10 front suspension, I relocate the upper bracket higher to maintain the stock 'mid-travel' height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-20-2025, 05:09 PM   #6
truckeroy
truckeroy's Avatar
Re: Dropped shocks
I'm going to find out. I just ordered a set of shocks that are 9 compressed and 13.5 extended for a 3" drop. The rear ones are 12" just like the stock ones. For a 4" drop. We shall see. Advertised for a 2-3 front drop and 4-5 rear drop. Being a retired engineer, I just couldn't resist testing the math.��
1948 Chevy 1/2T
