Old 09-17-2025, 07:57 PM   #1
Loose Screw
Loose Screw's Avatar
1968 C10 Front Bearing Replacement...
Gosh I'd like to get it done in a day.....
Man, I wish I could get away with just slappin a new outer into the old race. I don't think I'm going to be that lucky though.
I've done a job like this 40 years ago...
There'll be a lot of bangin and a lot of grease mess....
Hope it doesn't take me have a day to get the brake drum off........
And the Races oh those Sun of uh Guns.....punch them from behind from what I remember!
Loose Screw is offline   Reply With Quote
Old 09-18-2025, 06:59 AM   #2
RustyPile
RustyPile's Avatar
Re: 1968 C10 Front Bearing Replacement...
Is there a question?
RustyPile is offline   Reply With Quote
Old 09-18-2025, 07:36 AM   #3
Getter-Done
Getter-Done's Avatar
This punch in the link below makes getting the races out a little bit easier.
It has a different profile on the end which help it stay in contact better.
Link: https://www.amazon.com/Mayhew-24549-...114119916&th=1
The early bird gets the worm,
85 Chevy K-20
Old 09-18-2025, 10:33 AM   #4
Loose Screw
Not yet.....but advice like Getter-Done just gave is greatly appreciated!
Old 09-18-2025, 10:04 PM   #5
Getter-Done
This means a lot.
On most Bearing races a Person has to remove there is a wider lip to drive the bearing out.
Some are casted with two cutouts , this gives room for a regular punch.
Then some of them have a Small lip that is hard to hold a regular punch on to get a decent hit to remove it.
The way I determine this is, I take a shop rag or an old tee-shirt cut into sections.
I use a Screwdriver or long prybar to poke the rag thru.
That gets rid of the majority of the grease.
Then I use some brake cleaner to clean and dissolve the rest of the grease.
With this being done you can see what you are working on.
Hope this helps.
85 Chevy K-20
Old 09-19-2025, 12:24 AM   #6
Rust_never_sleeps
Rust_never_sleeps's Avatar
Worst haiku ever
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 09-19-2025, 01:15 AM   #7
Loose Screw
Got it done in about 3 hours (1 wheel). Went smoothly, brake drum came off with a few whacks of the mallet and there were openings behind the races to fit a punch in, I didn't have to catch just a lip, I could get in right behind the race to beat it out. Most of the time spent was cleaning/cleanup. The inner bearing was bad!
*A little side note: I saw some guy on YouTube say that the brake drums didn't have an opening to access the brake shoe adjustment wheel, yep my brake drum was hacked open!
Oh, and I know that a haiku is some sort of Chinese poetry, maybe I'll Google it.....
Old 09-19-2025, 04:24 PM   #8
LS short box
Haiku is Japanese I believe?
LS short box is offline   Reply With Quote
