Old 01-18-2004, 04:53 PM   #1
337
1st year for smog?
What was the first year for smog for these trucks?
I know it saw it somewhere on the board.
I tried searching for it and could not find the thread.
Thanks.
337 is offline   Reply With Quote
Old 01-18-2004, 05:03 PM   #2
toms68cst
toms68cst's Avatar
Many 68's were equipped with smog pumps. As far as I know no 67's were. I think only 1/2 tons were equipped not 3/4 ton's and above.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 01-18-2004, 05:06 PM   #3
337
Thanks.
Do you know what years require smog pumps?
Is this a state issue?
Old 01-18-2004, 05:57 PM   #4
bigjimzlll
bigjimzlll's Avatar
My 67 CA truck had all of the smog crap
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-18-2004, 06:07 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
It's most certainly a state thing...my '70 has never had a smog pump or anything of the sort on it.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 01-18-2004, 07:19 PM   #6
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
68 was first for PCV i thought. I didnt think there was any smog on 67 and lower
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 01-18-2004, 08:17 PM   #7
71Rat
ran out of money
71Rat's Avatar
i beleave pcv has been on engines since the mid 60's. the car co.'s didnt invent pcv for emissions. if i can remember correctly is was to prevent blow by and make the engines last longer since they wouldn't get gas into the oil and thin it out. if i am wrong someone please correct me. as for emissions i would guess it mattered what state it was in also. mine only had a charcoal canister.
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 01-18-2004, 09:53 PM   #8
toms68cst
toms68cst's Avatar
I agree it seems that CA trucks/cars had smog stuff earlier than the rest of the country.
I think around 70-71 they made the transitiion to heat risers rather than the smog pump set up. I've never seen on factory equipped with both in our series.
I think 68 was the first year they were widly equipped nation wide with smog pumps.
Old 01-18-2004, 10:47 PM   #9
Kenneth Brown
I can't tell you when it happened but I can say that 68 begins the year that you must have some sort of emmissions products. 67 and older may have an open element air cleaner where-as 68 and newer may not, at least for inspection purposes.
Kenneth Brown is offline   Reply With Quote
Old 01-19-2004, 12:16 AM   #10
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
My 69 3/4 ton had no smog pump. Just a heat riser, which I removed when it broke.
Cat Fuzz is offline   Reply With Quote
Old 01-19-2004, 01:54 AM   #11
whitesswj
Embrace the Redneck
whitesswj's Avatar
68 was first w/ PVC valve. Here in Missouri, they require that if it is equipped w/ the smog devices, it must have it. However if it was made before 83 or 4 you can take those divices off, but if the devices are still there they have to be in working order. after 83 they have to working period. I'm a MO state safety inspector #900023810. It is a state thing. Go to your local State Hwy patrol and ask for an inspection, free here in mo!
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 01-19-2004, 01:55 AM   #12
whitesswj
Embrace the Redneck
whitesswj's Avatar
Anything from CA will have it.
'01 Camaro
Old 01-19-2004, 02:35 AM   #13
68CST327
I'm an engine novice. What kind of smog devices should I be looking for? Where do they connect? What do they look like?
68CST327 is offline   Reply With Quote
Old 01-19-2004, 04:42 AM   #14
krazy_texan
krazy_texan's Avatar
my 72 had it, never seen it on any other truck
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-19-2004, 05:20 AM   #15
ILIVE4TRUCKS
AKA Phillip Johnson, AKA BANNED!
only 1/2 ton calif trucks had smog. None of the 3/4 trucks had it.
ILIVE4TRUCKS is offline   Reply With Quote
Old 01-19-2004, 08:12 AM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My 70 owners manual showed a bunch about smog stuff...but I haven't seen my manual for a couple years now.
Old 01-19-2004, 11:02 AM   #17
MrGoodpliers
MrGoodpliers's Avatar
Question
My '69 built and sold in Atlanta had it, but it's not required in GA, so maybe it was slated to be shipped to CA?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 01-19-2004, 11:09 AM   #18
toms68cst
toms68cst's Avatar
I don't know how It works but here's my smog pump. It's a belt driven pump with a bunch of plumbing to my exhaust manifolds.
Old 01-19-2004, 11:39 AM   #19
toms68cst
toms68cst's Avatar
I think by 68 smog pumps were required nationwide on all 1/2 tons not just CA. Canada would be another story though.
Instead of smog pumps some 68's and later were equipped with the heat risers.
I don't know of any other hard and fast rules.
