Old 09-25-2025, 12:39 PM   #1
truckeroy
truckeroy's Avatar
Master cylinder id
I have a 66 that already has the disc brake conversion up front. Has mid 80s style. The master cylinder is non power with a proportional valve. It's very hard to stop. The mc looks like a 67-72 style with the deep rod. No numbers on it. Could this be for a shoe brake setup? I can't figure out how to post a picture. When I do, I'll send it
1948 Chevy 1/2T
1964 Chevy 1/2T stepside short bed
1939 Pontiac coupe Street Rod
2005 GMC 1/2T short bed
truckeroy is offline   Reply With Quote
Old 09-25-2025, 03:15 PM   #2
truckeroy
truckeroy's Avatar
Re: Master cylinder id
Trying to upload a picture
1948 Chevy 1/2T
Old 09-26-2025, 01:35 PM   #3
theastronaut
theastronaut's Avatar
I have the usual squarebody disc swap on the front of my '66 C10 with stock rear drums. I used a 1" bore master cylinder without a booster and it stops great with plenty of braking power. The larger the master cylinder bore is the less hydraulic pressure it makes for the same input force, you might have too large of a bore. 1" is just right for me, you might want a 15/16" bore if you want an easier pedal, but without ABS and easy pedal makes it lock up too easily in a panic stop situation. 1" makes it easier to modulate near lock up.
If you have ceramic pads, they have a lower coefficient of friction and will make it harder to stop, you'll want to make sure it has semi-metallic pads with manual brakes.
New pads/rotors need to be bedded in or they won't stop nearly as well/as easily. If you've swapped pads but never gotten them hot enough to bed them in it will be harder to get it stopped.
theastronaut is offline   Reply With Quote
Old 09-27-2025, 10:13 AM   #4
truckeroy
truckeroy's Avatar
Thanks for the reply. The mc bore is 1". The pads are not new. This mc looks like a 67-72 style that was for shoe brakes? I don't know if the disc brake mc looks different?Plus, I have found leaking at some fittings. I'm in the process of running new lines.
1948 Chevy 1/2T
Old 09-29-2025, 08:56 AM   #5
rbruno68
Shouldn't the front reservoir be larger for the manual disc brakes? I will be hunting for a MC for disc/drum non power set up soon. At least for, me there seems to be a lot of confusion for which one is right.
rbruno68 is offline   Reply With Quote
Old 09-29-2025, 03:08 PM   #6
truckeroy
truckeroy's Avatar
If both reservoirs are the same size, usually it is for disc/drum or disc/disc. The earlier ones had a large bowl for disc and smaller for rear drum. Since mine is equal size,I'm assuming it's the correct one.
1948 Chevy 1/2T
Old 09-30-2025, 12:40 PM   #7
theastronaut
Did you use the tool to lock the pressure differential valve in the center position while bleeding the brakes? If not it’ll move and block off the circuit you’re bleeding, then that circuit won’t get any pressure to it.
This article explains it-
https://mpbrakes.com/proportioning-v...v6mlNxUmLcCC7_
Old 10-02-2025, 04:19 PM   #8
truckeroy
truckeroy's Avatar
I have to admit that is new to me. Thanks.
1948 Chevy 1/2T
Old 10-05-2025, 04:01 AM   #9
Agv63
When i converted mine to disc brakes ,i swapped out control arms and spindles from a 87 g10, that uses the 2" lca shafts.
I used a 1" master and stayed with manual pedal, it brakes but i do have to step on it, making emergency stops a bit of a worry. Did a dual diaphram 8" booster and drilled pedal to suit, staying with the 1"master. Made a worlds difference,my knee dont suffer anymore and no worries about stopping in time. Mine stops really quick and not locking up wheels. It is on the touchy side but i got used to it and prefer it that way.
Adriaan.
Agv63 is offline   Reply With Quote
Old 10-06-2025, 05:01 PM   #10
truckeroy
truckeroy's Avatar
Did you use the manual mc you had with the booster?
1948 Chevy 1/2T
Old 10-06-2025, 11:32 PM   #11
Agv63
Yes. This master is dual application has ports both sides and can be used manual and power. There is a small insert that looks like a bullet, goes into the piston to work with booster.
