Source for Door vapor Barrier and foam boarder
The other day when I was taking the inner door panels off, the white foam that goes between the door and panels, disintegrated from age and dry rot.
I also noted that there is no plastic sheet vapor barrier in either door. ![]() My question is: Is there a source for getting both of these items, or do I just need to fabricate my own? Thanks in advance |
#2 | |
![]() ![]() Join Date: Feb 2009
Re: Source for Door vapor Barrier and foam boarder
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Mar 2003
Plastic moisture barrier?? These trucks were built over 50 years ago. Was there even plastic back then? Now on my toyota I used 6 mil clear and cut it to shape
Thanks to both members.
I kinda figured on just getting the right sized foam and on the Plastic, It would be more of a dust barrier than moisture protection
| Bookmarks |
