01-18-2004, 06:30 PM | #1 |
plastic paints
any recommendations for paints that work good on small plastic items, like defrost and air vents , thanks
01-18-2004, 07:05 PM | #2 |
its all about the +6 inches
As long as your prep work is good, I have never had any problems with any paints at all.
Be VERY certian that the plastic is clean. Since it has small pores in it, the plastic will hold oils and armor-all type coatings and totally screw up your paint. Some spray bomb paint pre-cleaner does more than one would think. |
01-18-2004, 07:29 PM | #3 |
drag it like you stole it
you can try an adhesion promoter as well. i have had good luck with Bulldog. you can purchase it at just about any automotive paint store.
negative camber //LA\\ |
01-18-2004, 07:45 PM | #4 |
BlahBlahBlah
ive used model paints with good luck. plastic is what they are made for, but i have to agree with the good prepwork post. thats the number one thing.
01-18-2004, 09:30 PM | #5 |
Try a good seal.............
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-18-2004, 09:38 PM | #6 |
I just painted my console and door pillar cap with SEM plastic color coat paint and it turned out great, looks like it came from the factory.
01-18-2004, 10:07 PM | #7 |
I use Krylon Fusion - its for plastic. Works very well. I got it at Wal-Mart.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-18-2004, 10:13 PM | #8 |
PROJECT 7DEUCE
I second the fusion work's great... On plastic's that have been around awhile I use adhiesion promoter along with a through prep job..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-19-2004, 12:58 AM | #9 |
Bulldog...I was trying to remember the name of that stuff...it is awsome.
