| View Poll Results: Which gear for a 54 Chevy 210. | |||
| 3.91 gear |
1 | 20.00% |
| 3.73 gear |
2 | 40.00% |
| 3.55 gear |
2 | 40.00% |
| Voters: 5. You may not vote on this poll | |||
54 Chevy 2 door post rear gear.
I am slamming my 54 210 post back into a modern safer daily driver.
1979 Buick 231 V6, slightly ported heads, gasket matched heads/Edelbrock intake, hei with weight kit, th200r4, and a Isky mile a mor cam. The rear tires are 245/45r17. Or 25.5 inch installed height roughly. Daily curb wieght with me ,and my son in it should be just under 4000 pounds. Cam specs. Valve Lift Int/Ext. 0.425/0.425 Valve Lash Hot Int/Ext. 0.000 ADV Duration Int/Ext. 248/248 0.050 Duration Int/Ext. 194/194 Lobe Center 108 So which gear ratios would you Vote for. Cruising rpm defined as 75 mph to keep up with traffic easily. 3.89 gears with a 2589 cruising rpm. 3.73 gears with a 2470 cruising rpm 3.55 gears with 2351 cruising rpm I am leaning to the 3.91's for better street manners. As that would be most of it real day to day. I currently rarely hit the freeway except to go on a trip litterly. Plus the factory straight 6 used 4.11's with its overdrive trans, and slightly taller tires. |
| Bookmarks |
