Old 10-11-2025, 07:15 PM   #1
Sicklajoie
The Niner
Sicklajoie's Avatar
Phenolic spacer for stock 402?
Hello all,
I have problems with my truck cutting out under a heavy load on warm days after gassing up or if I've been sitting at a drive-thru or a stop light for extended periods of time.
I'm wondering if a carb spacer would do the trick.
I have a stock 402 with headers and a stock Rochester Quadrajet carb.
If anyone has any recommendations on what brand you've used and any additional modifications that are necessary after installation I would greatly appreciate it.
Thanks!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 10-11-2025, 09:11 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Phenolic spacer for stock 402?
Originally Posted by Sicklajoie View Post
Hello all,
Thanks!
I put one on my White '67 with a 454 engine with a Quadrajet after experiencing the very same problems you now have. It was a 1/2" or 5/8" Phenolic that I bought from Summit. It also helped with the hard starting after sitting for a while when warmed up.
Leon
Old 10-11-2025, 09:32 PM   #3
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Heating at idle is lack of air flow. Heating on the highway is from lack of water flow. My truck used to never start for about half an hour or so after being shut off; that went on for years, before I got it. If your radiator is clean, and your fan is properly coupled to the shroud, and the fan clutch is good, you might look into a high flow thermostat. It took me awhile to get it ironed out. I don't have a phenolic spacer. How hot does you truck run? My fan was not properly coupled to the shroud; I made a new shroud from aluminum that couples the fan properly. It still ran hot until I replaced the thermostat.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-11-2025, 10:38 PM   #4
Sicklajoie
The Niner
Sicklajoie's Avatar
Engine temp is fine, runs about 180 on a warm day with a 160 hi-flow thermostat. I rely on an infared gun instead of the temp gauge and the t-stat housing runs about 170-180 when I point the gun at it.
Old 10-11-2025, 11:18 PM   #5
Steeveedee
Steeveedee's Avatar
I have nothing more to recommend. I do hope that when you find the solution, you will let us all know. I chased my tail for a bit. If you buy a phenolic block, make certain that that thing is flat before putting it on. I had a 305 SBC that I put an Edelbrock carb on. Had heat soak problems and put the Edelbrock phenolic spacer on it, but it leaked vacuum like a sieve. I sealed it up with Form-A-Gasket (we used to use a similar substance to seal vacuum leaks on the main condensers under the turbines, in the Navy), but I'll never use one of those spacers again. Edelbrock was worse than useless about it; they never even replied, when I complained.
~Steven
Simi Valley, CA
Old 10-12-2025, 02:54 AM   #6
SRU1436
I used the summit brand for a Holley on my Chevelle. Works good with no issues.
SRU1436 is offline   Reply With Quote
Old 10-15-2025, 09:03 PM   #7
yuccales
yuccales's Avatar
Been running this 1" from Summit for years. Solved the long cranking on a hot engine.
yuccales is offline   Reply With Quote
Old 10-16-2025, 11:34 AM   #8
Getter-Done
Getter-Done's Avatar
I had similar issues.
What resolved mine was changing the 160 degree thermostat out for a 195 high flow thermostat.
It not only help with the carburetor loading up, it help maintain a steady temperature.
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-16-2025, 07:35 PM   #9
Sicklajoie
The Niner
Sicklajoie's Avatar
I'm going to switch out the 160 stat for a 180 and drill a hole in it.
Old 10-16-2025, 11:20 PM   #10
Getter-Done
Great Idea that will take care of the flow..
I have forgotten this trick.
The Machinist in me cannot help but suggest.: lol:
I would take a Twist drill several sizes bigger and Deburr the front and back side of the hole drilled.
This can be done by just hold the Twist drill in your hand.
I hope this works.
I have been down this road and it is satisfying when you find the issue with your particular issue.
85 Chevy K-20
Old 10-17-2025, 12:36 PM   #11
c30
Active Member
c30's Avatar
My 77 k10 400 small block was having severe vapor lock issues when I first bought it.
On a hot day, it would not restart for about a half hour after shutting it down.
I was thinking through all the remedies until one guy suggested that my mechanical fuel pump was tired. He was stating all the various problems caused by a weak pump.
These include some of the problems that you are having.
I put a new pump in it and all my problems went away.
c30 is offline   Reply With Quote
Old 10-17-2025, 03:08 PM   #12
Sicklajoie
The Niner
Sicklajoie's Avatar
Thanks.
I'm covering all my bases and getting a new Carter fuel pump also.
Thanks to everyone that's responded with help and additional suggestions, much appreciated!
Old 10-19-2025, 11:07 PM   #13
Mike C
Mike C's Avatar
The OEM big block air cleaner sits just under the cowl, and a spacer may or may not cause it to not fit. If it does, great, if not consider the GM style heat shield with the thick gasket and aluminum plate. Here is a link to one at TopFlight, they were just the first one i saw.
https://www.topflightautomotive.com/...iABEgKNsfD_BwE
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-20-2025, 04:49 AM   #14
Sicklajoie
The Niner
Sicklajoie's Avatar
Great thanks!
Old 10-20-2025, 10:10 AM   #15
1970cstblazer
1970cstblazer's Avatar
Question Re: Phenolic spacer for stock 402?
Are you running 10% ethanol blend fuel or straight gasoline?
Old 10-20-2025, 01:32 PM   #16
Rust_never_sleeps
Rust_never_sleeps's Avatar
I had one of these on my 350. Not photogenic, but it worked fine.
My neighbor convinced me it wasn't original, and for some reason that bothered me at the time ;-)
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
