Old 01-18-2004, 07:02 PM   #1
jorgensensc
jorgensensc's Avatar
Heater levers?
Sorry to do this, but I don't have time to search through all of the previous posts, nor do I have time to look at all the vendors catalogs..
So, who sells the good metal (not potmetal) levers? Mine broke and I'm getting sick of fumbling around under the dash to turn my heat on and off.
Prices for the levers, and all three cables would be good too.
I don't know if I can get the cables right now, but I will get the levers immediately.
This thread is open to vendors as well as any member suggestions!!
Thanks!!
Shawn
BTW this is for a heater only truck, non A.C..
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-18-2004, 07:19 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Just ordered mine from GMC pauls. around 30 bucks for the steel ones and they come with a new face plate
WRMZ71 is offline   Reply With Quote
Old 01-18-2004, 07:48 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Old Air Products over in Fort Worth makes them. Last set I bought was from Kenny's Truck Parts for 20 bucks.
On edit : It's the kit that comes with all three levers and knobs and the new face plates. They call them the "never pop" levers because they aren't pot metal and are guaranteed not to break.
Old 01-18-2004, 08:25 PM   #4
jamie72
jamie72's Avatar
e-mail tim christian tell him what you need he`ll fix you right up..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 01-18-2004, 09:21 PM   #5
Blue Beard
Blue Beard's Avatar
make sure you ask for the ones that won't brake...........
the old ones were pot metal type and broke fairly easy....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-18-2004, 11:44 PM   #6
jorgensensc
Thanks for all of the info!!
Tx Firefighter, 20 bucks sounds like a good deal!! Are they a vendor on the board? (I kinda like to throw my money that way ).
Does any one have any suggestions for how to lube the cables up? Mine work, they are just really hard. Should I just buy new ones, or will they lube up fine?
Thanks again for the replies!!
Old 01-18-2004, 11:56 PM   #7
Tx Firefighter
Kenny's Chevy trucks is listed on the main page. Their website is down, but I called him last week and he said his host went out of business, but business was still as usual. I always buy from Kenny, he's been selling me parts for 9 years now. I've restored 4 trucks using his stuff.
Old 01-19-2004, 02:35 AM   #8
Tim Christian
Tim Christian's Avatar
$20.00 bucks is a good buy! I have them in stock but mine are $28.00 Sorry But let me know if I can help you. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 01-19-2004, 03:09 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
If you have the time to do this, this is the way I lubricated my cables and it worked very well. They were very stiff and one would barely move when I took them out. After I removed them I took some Liquid Wrench and sprayed the ends and started working the cables, sprayed more, worked, sprayed, worked, until they loosened up, I then took 3 in 1 oil and placed several drops on one end working the cable in and out several times and applying more oil after it soaked in, I then hung the cables overnight, the next day I did the same with the other end using the oil and working the cable, I then hung it up using this end overnight, then I repeated this process one more time with the other end. Now the cables work VERY smoothly just like a new one would!!! Good luck with it!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-19-2004, 08:34 AM   #10
Tx Firefighter
Tim, the price from Kennys was at a swap meet when I bought over a thousand dollars from him all at one time. He cuts deep discounts when I do that. I just looked in his catalog and they're like 26 bucks usually. This is for the Old Air repair kit.
Old 01-19-2004, 08:39 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
Bought mine from Chevy Duty (www.chevyduty.com) was before I discovered all the great vendors on this board. Good quality though.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
