Old 10-14-2025, 12:54 PM   #1
sodly
sodly's Avatar
Engine wiring harness question
Can anyone tell me how to remove the wires from this engine harness plug (1966)? This is the plug that plugs into the firewall. How do you remove a wire from it? Do you need to stick something into the plug to release a tang? I have one wire that's developed a bare end that needs to be cleaned up. Probably will have to remove all of them from the plug to fix the one.
Anyone know what style of spade is on these wires that goes into that plug?
By the way, the problem wire is different than the others. It has sort of a metal braided coating, unlike the others that are colored plastic. Anyone know off hand what this wire does? The wiring diagram is unclear. This is a completely stock 327 truck.
Thanks!
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 10-14-2025, 03:09 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Engine wiring harness question
I read this over on the Electric section of the forum, but I'd ask there to be sure. Subject is a 69 truck so not directly applicable.
I'm sure VetteVet will know.
https://www.67-72chevytrucks.com/vbo...l+braided+WIRE
Next is the cloth covered wire that started life as an orange/purple white wire that is a resistance wire to protect the ignition coil from overheating during normal running. It drops the ignition voltage to approximately 8 volts to the positive side of the coil. It joins a yellow wire which goes to the I terminal on the starter solenoid. This I terminal sends a full 12 volts to the coil during starting for a hotter spark while the engine is cranking.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-14-2025, 04:35 PM   #3
sodly
sodly's Avatar
Thanks, MusicMan70. Duh! Didn't even think to ask there.
WANTED:
Old 10-14-2025, 06:11 PM   #4
ray_mcavoy
That connector uses Packard/Delphi (now Aptiv) 56-series terminals.
Here is a video showing how to remove them --> https://www.youtube.com/watch?v=beAQpdTXIgw
You'll be dealing with the male terminals on the engine side of the harness.
ray_mcavoy is offline   Reply With Quote
