Front wheel bearing seal
1971 C20 Spindle
This rotor does not look properly seated on spindle. From reading on here the seal does NOT mount flush. Should the seal not run on the Spindles most inner race?
1968 GMC 920 Longbed Original 307 Last edited by airkore65; 10-19-2025 at 02:01 PM. Reason: Adding details to image |
PROJECT 7DEUCE
Re: Front wheel bearing seal
Id say the seal should be on the clean edge...
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Well to start it looks to me the seal is not all the way installed in the rotor. It should be flush with the edge of the rotor hub. If it was me I would remove the seal from the rotor and test fit the seal on the spindle. Before test fitting it clean off the spindle and check for burrs sand accordingly. Then apply some grease to the spindle where the seal goes and test fit.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Shouldn’t there be a dust shield between the seal and the spindle?
#5 | |
![]() Join Date: Dec 1999
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Seal is in correct orientation. These seals from reading on here do NOT sit flush.
Regarding the dust shield - very hard to find a C20 shield for these trucks.
1968 GMC 920 Longbed Original 307 |
| Bookmarks |
