Old 10-19-2025, 01:06 AM   #1
Ianmattchevy
Finding out gear ratio in 12 bolt
Hey all - looking for some help and info. I recently bought a 61 pig-nose c10. the 10 bolt rear is bad and I found and purchased a 12 bolt from a 63 C10 ( at least I'm told ). Anyway i would love to confirm what ration it has. The stamping on the axle is as follows:
Ha 01 15
Thanks for the help.
Ianmattchevy is offline   Reply With Quote
Old 10-19-2025, 03:01 AM   #2
Shark_13
Re: Finding out gear ratio in 12 bolt
Turn the pinion and see how many times it takes to turn the wheel one full revolution
Old 10-19-2025, 09:07 AM   #3
Keith Seymore
Keith Seymore's Avatar
Pull the cover and count teeth. Change the fluid while you are at it.
No telling what's in there after 60+ years.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-19-2025, 12:38 PM   #4
Accelo
Accelo's Avatar
I was unable to find the HA code.
The gear ratio codes are located on the front passenger side of the differential as shown in the illustration below. This code will tell you the ratio, whether it is posi or not, any special notes and what plant it was made at.
Accelo is offline   Reply With Quote
Old 10-19-2025, 09:37 PM   #5
Ianmattchevy
so here are the stamped numbers on the axle:
Ha 01 15 w
Here are the numbers on the ring gear inside the 12 bolt:
3817778 11:41 gm 12-67 1
here are the numbers on the outside of the carrier near the yoke:
N 3896838
Old 10-19-2025, 10:29 PM   #6
geezer#99
geezer#99's Avatar
The 11;41 means 3.73 gear.
Old 10-26-2025, 05:23 PM   #7
Pick121
Pick121's Avatar
Is the stamp “HA” or “Ha”?
Found this on another site, could it be a 1965 12 bolt? If so it does look like it’s a 3.73/ non Posi
-Pickman (Mike)
1964 C10 Fleetside LWB “George”
1963 C50 “Green Machine”
[SOLD] 2019 Silverado 2500HD
2020 Silverado 3500HD
My story (Welcome Page)
Pick121 is offline   Reply With Quote
Old 10-26-2025, 06:17 PM   #8
Keith Seymore
HA.
Broadcast (pick) codes are always all upper case.
K
1979-1986
1986 - 2019
Old 10-27-2025, 09:55 AM   #9
MikeN
MikeN's Avatar
Correct. (41 ring gear teeth divided by 11 pinion gear teeth) = 3.727273 which rounds to 3.73
MikeN is offline   Reply With Quote
