Old 10-19-2025, 10:02 AM   #1
scott123
3/4 ton to 6 lug
Posted this is a different view a few weeks ago.
In some swapping a trading I wound up with a front end from under a 1970 3/4 ton with an 8-lu wheel pattern. It is brand new. Down to the controls arms were purchased with ball joints riveted in not bolted. Every part that could be replaced was replaced. Super nice.
I have a 1969 1/2 ton with the 6 lug bolt pattern. I would like to bolt the unit it but retain the six lug bolt pattern.
I have googled and AI'ed and hit several forums.
AI/Co-pilot says H&H makes a bearing to make up the dimension differences between the 1/2 ton hub and the 3/4 ton spindle. H&H says they do not offer such a part.
Then wheel adapters are an option.
Anyone ever drilled spindles to accept the larger 3/4 ton ball joints? I have taper drilled a ton of Camaro spindles to run Chrysler ball joints on a dirt late modified/clipped car. I'm still using Camaro control arms and spindles just bigger ball joints.
And the last option is to rebuild the 1/2 ton unit and miss out on saving some $$$ by using something I already have.
Thoughts?
Scott
scott123 is offline   Reply With Quote
