Old 10-22-2025, 11:58 AM   #1
Daron Craig
65 Stepside C10 (What is the widest tire/rim I can run)
I figure with the amount of torque I'm going to have I need/want to run the widest tire and rim possible. I was thinking at least a 275/60r15. Maybe 295. I want to stick with the white wheels, but I doubt the rear wheels on there now will support more than a 255. I think they are a 15x7, but I haven't measured them yet. Thanks in advance.
Daron Craig is offline   Reply With Quote
Old 10-23-2025, 03:37 PM   #2
forestb
forestb's Avatar
Re: 65 Stepside C10 (What is the widest tire/rim I can run)
I have a set of 275/55ra7 in the rear on a 17x8 wheel and it is really close. I had to flair the lip of the fender to get them to fit. I have 275/50r17 up front. It also depends on how low your truck is. I have a 5 inch drop in the rear. It can also vary by truck. some fenders are a little smaller thinner than others and it can also depend on the lean of the bed side. I used to have a set of 275/60r15 with a 15x7 on the rear and they fit fine with no lip rolling.
forestb is offline   Reply With Quote
Old 10-28-2025, 10:55 AM   #3
Daron Craig
Thanks for that info. I was planning on running 15x8 with 275/60r15 tires on the rear.
Old 10-28-2025, 11:23 AM   #4
forestb
forestb's Avatar
That should be fine but you might have to do a little massaging to keep it from rubbing a little. A lesson that I recently learned from trying to find the right wheel and tire combination for my Thunderbird is that you should buy one wheel and one tire and see if it fits. I bought a full set of wheels and tiers and they fit until I tried putting on the fender skirts and those would not work with the tires. I even bought the same width of tire that was on the car originally. Now I have to buy a hole new set of wheels.
Old 10-29-2025, 01:27 PM   #5
Daron Craig
Good idea. Is there a backspacing you guys recommend?
Old 10-29-2025, 01:52 PM   #6
forestb
forestb's Avatar
I think the 15x7 inch wheels I had before had a 4 in backspacing. The 17x8 that I am currently running are 4.5 inch backspacing.
Old 10-29-2025, 01:54 PM   #7
Daron Craig
Thanks for the info bud
