Door skins
56 truck
any new door skins being made?? Passenger side |
![]() Join Date: Jul 2007
Re: Door skins
I don't remember the last time I saw door skins available for any 47/72 Chevy truck. I'm not sure now that they were even an aftermarket item and may have been though dealer parts counters. It's been since the 70's that I have seen anything on replacing a door skin on anything.
All Auto metal direct shows is the lower door skin sections.
Re: Door skins
how high up do you need to go? might hafta make your own.
Re: Door skins
From the bottom up to just above this body line.
Re: Door skins
that'll be a home built panel I think. if you could make it UNDER that boy line it would be easier, unless you have a break.
I will be doing the same panels on my doors when the time comes. just under that body line. gonna be a home built panel cuz I haven't found a tall skin like that. a full aftermarket shell is big bucks here in Canada and likely wouldn't fit anyway. is your panel rusty, dented? |
#6 | |
Re: Door skins
Cut below. Better chance of a good outcome.
![]() Join Date: Feb 2004
Re: Door skins
This is where putting insides and outside bottom worked best for me on my 59..
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt |
Re: Door skins
Thanks for the info but I still need the panel
Re: Door skins
Try GMCPauls
Classic Industries Tuckers Ebay Ecklers
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt Last edited by dennislbrooks; 11-09-2025 at 02:52 PM. Reason: words |
| Bookmarks |
