![]() Join Date: Apr 2010
69 Blazer
I just bought a 69 Blazer and I'm wondering what engine is in it, the code on the block is: F0721TLS and under that is T7S529657 does anyone have an Idea what engine this is, the engine really close to the firewall and can't see what the number is on the back of the motor! thanks for any help
Re: 69 Blazer
Nasty Z/28 says that suffix is for a ‘75-‘77-‘79 400 small block. How many freeze plug bosses are on the side of the block?
Re: 69 Blazer
really hard to see anything on the right, with the motor mount and headers I can't even see 1 freeze plug
Re: 69 Blazer
This transfer case is in my 69 Blazer, is this original for 69 Blazer? It has Dana c18-15-38 on it, thanks for any help
All about them K’s
![]() Join Date: Jun 2014
Re: 69 Blazer
Yes the Dana 20 was available in 69
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: 69 Blazer
I believe one can see the reliefs in the pan for the rods on an SBC 400. If you have an engine handy that is known NOT to be a 400 you can make a comparison from underneath?
Re: 69 Blazer
Re: 69 Blazer
All about them K’s
Re: 69 Blazer
Look at the harmonic balancer. SBC 400 is externally balanced. All other small blocks are internally balanced. The balancer will likely look like that of one of your big blocks, and be totally different than all other small block balancers. Also I’m pretty sure the Saginaw was available in the 69 blazer and was exclusively paired to the Dana case. I think every other tranny option got the 205, as it was introduced in the 69 blazer as far as GM stuff goes.
Re: 69 Blazer
here is a picture of the saginaw in front of the Dana transfer
Re: 69 Blazer
Would there be a high hump made for this set up?
All about them K’s
Re: 69 Blazer
You can make any 67-72 high hump work, you’d just have to patch/cut where needed. Finding that particular one with the cut outs in the right place is probably not going to be easy, as that’s not a terribly common setup.
#13 |
Re: 69 Blazer
It does have a high hump in it but it looks like someone butchered it and the harmonic balancer does look like the ones in my big block trucks. It needs a new clutch so I have to pull everything apart, not a fun thing to do laying on your back
| Bookmarks |
