Rear End Cover Gasket Installation?
What is the best way to instill the gasket for the cover on the rear end? Is that little paper gasket the best thing to use? Thanks
Cause the Chicks DIG IT!!
Yep the paper diff gasket is the way to go. I think if I remember correctly when I did mine that I put on a little bit of silicone too as well just to hold the gasket in place when i went to bolt it on
most people just use silicon,no gasket.
#4 | |
#5 | |
gasket
its all about the +6 inches
We use 3 M Super 77 Multipurpose Adhesive spray at the shop. Spray on one side of the gasket, let it tack up, and place it on the diff cover. (or water pump or valve cover...what ever we're workin on) Then just bolt it on.
However, for a diff, we just use The Right Stuff most of the time. |
I use a thin coat of 3M weatherstrip adhesive on the gasket and the cover only. Let it tack-up and stick it, then bolt 'er up. Make sure to straighten the sheet metal cover if it's distorted at the bolt holes.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
How much gear lube for a standard truck 12 bolt? Thanks
I think it was just under 2 bottles, but I am not quite sure.
One thing I've found when people use the silicone or rtv sealer...........they always seem to miss a spot...............now the leaks........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
