Old 10-30-2025, 03:36 PM   #1
51 3600
Filler neck question
I'm using the stock AD filler neck connected to a rear mounted tank exiting at the top back of the driver rear fender. Is a stock gas cap vented? I ask because I'm assuming the vent hose from the tank to the filler neck is adequate for venting so I don't need to use the available barbed vent fitting on the tank. (Disregard the position of the hose clamps. They're looses at the moment.)
Al
'51 3600, LS5.3, 4L60e, Danforth cross., Blazer front susp., Borg Warner 9 bolt 3.27 GR, Wrangler leafs
51 3600 is offline   Reply With Quote
