Speedometer - any difference in gearing within the gauge?
As the title says - is there any differences within the gauge gearing, or does it just come down to the gearbox cable gear? Background for context:
So to my original question: could there be any gearing differences in the speedometer unit itself? I wouldn't have thought so, but despite the needle bouncing with the original speedo, I thought the speed reading was about right (the bouncing was far less at lower speeds)....but maybe I was imagining that! For the record, it is an original 3-speed manual gearbox and the tire size is 6.70x15, so everything is factory stock. I didn't touch the speedo cable gear in the gearbox. I could always pull the cluster AGAIN, replace the specific odometer gear in the original gauge and see if that answers my own question...but that will be a PITA (the speedo cable nut is an exercise in hand contortion I'd rather not go through again!), so I'd rather have a definitive answer before doing so. Any thoughts appreciated! |
Re: Speedometer - any difference in gearing within the gauge?
They should all be geared the same. All changes happen at the transmission. Could it be possible that your “new” speedometer is dragging (not sticking) a little? I do know that a speedometer shop can fine tune it by manipulating the magnets in the unit (not sure what the exact science is, but I know they don’t change gears). In the old days there was a speedometer shop in every town, but now there are just a few mail order places. I’ve sent units away to be calibrated and it’s not a big deal. They also clean and lube them.
I agree getting to the cable nut is no fun, done it too many time and it never gets any easier! Good luck.
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
![]() Join Date: Mar 2006
If the speedometer needle is smooth and steady and consistently wrong, I’d take the win and adjust at the transmission. Depending on your trans, there are different tooth counts available or you could do the math and order a ratio conversion box based on your tires and differential.
Check that the odometer is accurate since its mechanically directly connected to the trans. If its correct then you can tell if your speedometer is calibrated correctly or not. If its not correct then adjust the speedometer drive gear in the trans to correct the odometer reading first, then have the speedometer calibrated.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Thanks everyone, and a good point you raise Short 3/4, perhaps it is dragging. I think the 'easiest' solution for me might be to pull the gauge again, replace the odometer gear from my 'new' unit into the original gauge...and hope that it isn't the source of the dragging! I'll do it eventually, once my cable nut PTSD has dissipated! If it wasn't for that, the job of pulling the gauge cluster and reinstalling would be pretty easy.
Theastronaut - that's a good idea re checking the odometer reading, so I'll give that a shot. As a complete aside, I see they've finally made a movie using your name..but I doubt it features any pick-ups in it
| Bookmarks |
