New Member
![]() Join Date: Dec 2023
Looking For Help And Guidance For Outer Floor/Inner Rocker Replacement
Attached are a couple of pictures of my lower hinge/A pillar and my lower latch/B pillar. First, I would like to remove the outer floor/inner rocker. The inner rocker is sandwiched between the cab supports and the lower pillars with spot welds, bolts and nuts. I am looking for a way to remove those pieces of the outer floor/inner rocker and replace teh outer floor/inner rocker with the AMD/Tri Plus outer floor with inner rocker panel (part number 406-4067-1R). I am trying to avoid having to remove the lower pillars, since they are in relatively good shape (and avoid the extra work and cost of removing and replacing). For reference, I will have to replace the lower section of the kick panel and the lower portion (about 3") of the cab corner.
Looking forwared to hearing back! MCSETots
Eastern Washington 1967 Chevrolet C20 Fleetside Custom Camper Original 327 cu in |
| Bookmarks |
| Tags |
| 1967, fleetside |
