PROJECT 7DEUCE
![]() Join Date: Dec 2002
Need body mount's...
Here's what I did I took a 3/4 ton frome made it a 1/2 and put the original cab from my 1/2 ton on 3/4 ton frame. I have seen some post about the 3/4 and 1/2 ton's haveing different body mount's. What bushing;s do I need to use 1/2 or 3/4 ton...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
since it is a 3/4 frame you will need 3/4 mounts because i dont think the cabs were any different between the models.
70 longbed 496/th400/Ford 9" |
