Old 11-12-2025, 08:23 PM   #1
mike16
72 c10 pinion nut torque specs?
Replacing the yoke and pinion seal on my 72 c10 axle.
What is the torque specification on the pinion nut.
Any other advice?
Thank you.
mike16 is offline   Reply With Quote
Old 11-13-2025, 09:37 AM   #2
Mike C
Mike C's Avatar
Re: 72 c10 pinion nut torque specs?
There is no pinion nut spec. The 12 bolt is assembled with a crush sleeve and it is torqued to a specific rotating resistance measured in inch pounds.
I have found that when replacing a yoke or seal, if you just tighten it as tight as you can get it with a standard 1/2” ratchet, that will get it done.
If you tighten too much you change the preload on the bearings. I recommend you replace the pinion nut when you do this as the locking ability of the nut is reduced after use.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-15-2025, 09:24 AM   #3
super72swb
super72swb's Avatar
I have watched several how to videos and you torque to 25 in lbs of drag while rotating the yoke… please do your research research
super72swb is offline   Reply With Quote
Old 11-15-2025, 10:48 AM   #4
mike16
Thanks for the advice. I did research and got essentially three different answers.
Old 11-19-2025, 05:12 PM   #5
ullose272
thats really not even correct, pinion bearing preload is set without a diff carrier installed, and is different with new vs used bearings. rotating the diff, axles, ect will show a high rotational resistance but actually not have enough on the pinion bearing.
What Mike C said will get you in the ball park, you wont be able to get it perfect without disassebly
ullose272 is offline   Reply With Quote
Old 11-19-2025, 10:40 PM   #6
WorldsCrappiestTruck
Above is right. Pinion only, no carrier, tighten the bejeezus out of it until you get rotational drag (or a torque reading on a dial or bar type torque wrench).
To do this for me, I put a pair of 1/4” extensions into the holes on the yoke that hold the ujoint straps, then trigged a bar between them and over to the trailing arm, so as I tightened the nut, the apparatus would keep the pinion from turning.
From there I had a 2-foot 1/2” breaker bar, then the handle of my jack shoved over the breaker bar to properly crush the sleeve - probably 4-5’ of leverage. It takes a lot.
WorldsCrappiestTruck is offline   Reply With Quote
Old 11-22-2025, 06:40 AM   #7
MikeB
MikeB's Avatar
Here's the procedure I learned from a hotrodder who worked as a Ford mechanic for over 30 years, and now has his own shop working on hot rods and muscle cars:
When replacing a pinion seal, get the rear wheels off the ground, remove the driveshaft, and then measure how much torque it takes to turn the pinion. Go ahead and replace the seal, reinstall the yoke, and then tighten the nut, checking pre-load frequently. Once it's the same as you measured in the first step, you're done.
This won't be as accurate as doing it with the carrier removed, but pre-load is now back to where it had been for any number of miles. Also, he recommends re-using the old nut, and using thread locker on it.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-22-2025, 08:42 AM   #8
ZEKE68
ZEKE68's Avatar
13-15 in-lbs for new bearings and 6-7 in-lbs for used bearings, while rotating the pinion, with no carrier in place. This is for 12 bolt truck rearend. I have marked the nut, and replaced the seal, then retightened the nut to the mark, maybe just a hair past, before without problems.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 11-22-2025, 03:18 PM   #9
MikeB
MikeB's Avatar
Sounds like a good way to go.
Mike
Old 11-23-2025, 02:52 PM   #10
volksworld
think the magic question is how many ft lbs does it take to cause the collar to crush...as long as you stayed under that number you wouldn't alter the preload...tried to ask a buddy that built rears what that number was and his reply was something along the lines of ''you have to tighten the f**k out of them"....thanks...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 11-23-2025, 05:09 PM   #11
LS short box
So on my hot rods with GM 10/12 bolts the local rear end builder hasn't used crush sleeves for years. He uses shims to get the correct pre-load. He says it makes changing out the pinion seal if needed is so much easier.
LS short box is offline   Reply With Quote
Old 11-23-2025, 11:38 PM   #12
MikeB
MikeB's Avatar
Probably true, if you knew what that number was. But simply measuring the pinion bearing preload before disassembling means you don't have to care about how much torque it took to compress the crush sleeve when the rear end was set up.
I've done a few crush sleeves, but couldn't tell you what the numbers were because I didn't have a torque wrench that would show over 250 lb/ft. All I cared about was crushing the sleeve to the point where I had the proper pinion bearing preload. However, I'd guess it was 250-300 lb/ft.
Mike
