![]() Join Date: Jan 2015
68 c10 swb
Building a house truck has been sitting everything except truck itself and aluminum LC9 short block is brand new. Build as seen here
https://67-72chevytrucks.com/vboard/...d.php?t=850071 I have focused on all the chassis engine and transmission for drivability first. Rockers and kick panels have rust as usual and I haven’t made it that far. Wiring is all hidden in engine bay with remote power location on core support. Rear license plate mounting bracket New front and rear chrome bumpers Speedway Motors deluxe lowering kit 3/5 with shocks, lowered shock brackets and tracbar LMC heater controls, ducting, defrost vents, fan clutch, door felt kit, Rear brake drums, brake pads, spring kits, adjusters, wheel cylinders and e-brake cables License plate box Headlight switch New dash pad New door felt and weatherstrip Yukon rear axles, axle bearing’s and axle seals CPP c-notches CPP trailing arm crossmember LMC led license plate light, reverse switch, fuel sending unit, pedal pads, heater core and heater resistor LMC radiator with brushless PDM Chevy volt fans 2” blocks and u-bolts Control arm cross shafts and upgraded u-bolts Lowered seat brackets Coolant reservoir CPP disc conversion with 2.5” drop spindles Shift linkage GM 1” bore master with proportioning valve Rubber front brake lines Pitman arm and idler Powder-coat front crossmember, a-arms, motor mounts and center link Borgeson quick ration steering gear box 34/78 Optima battery holder Alingment with camber mod Shorten driveline for 4L80E Derale 15960 frame mount Derale 13960 transmission cooler Flywheel dust cover Terminator x max BTR Truck Norris cam 212/22x .552”/.552” 107 LSA AS59 standard MAP sensor 12608814 A/C Delco CTS SS11397 Delphi crank sensor GM 12591720 Cam sensor OEM coils 12699382 GM TBSS intake Standard Ignition FJ1089 injectors GM 87mm dbw 12679524 TB Holley 554-121 MAT sensor 0-100psi fuel pressure sensor LS engine Oil pan Melling m365 oil pump Rear main seal Oil barbell Felpro 26190pt head gskts dod delete valley cover Oil pressure sensor Head bolts Timing gasket and seal Cam sensor BTR Truck Norris cam, springs, seals Lifters, trays and pushrods Arp cam gear bolts Knock sensor Timing chain tensioner Cloyes timing set Steam kit Valve covers Balancer/pulley Water pump Water pump bolts Billet engine mount Heads rebuilt and surfaced High torque starter Starter bolts Conversion flexplate Alternator/power steering pump billet bracket d514a coils w/wiring Holley terminator x max Complete new TBSS intake with throttle body, injectors and fuel rails Aeromotive fuel filter and pressure regulator Hydroboost brakes New 160 amp delco alternator New power steering pump DBW throttle bracket DBW corvette throttle pedal Dipstick and tube Speed 1 7/8 header with gaskets, bolts and vbands 3” mandrel exhaust to before diff with Flowmasters 4L80E built by “the 4l80e guy in Gresham Oregon 750hp capable FTI 3600 rpm converter New driveline LED markers and taillights Reversion Raceworks 3D printed dash for Holley 12.3 pro dash Holley Pro Dash 12.3 OEM rebuilt steering column 2” shorter with shaved indicator Boyd’s welding fuel tank with in tank pump Optima batter remote mounted rear of frame Welding cable battery cables These are just a few things on my cell list. Plus many more as can be seen in my build post. I have way more money invested than I would imagine. Asking 30k I also just installed a set of 17” white custom offset steelies and new nitto tires that have only been mounted balanced and installed. I have both rocker panels, new door rubbers, radiator support rolled panels, weld in fuel plug for cab, firewall weld in plates and much more. I will post more pics and answer any questions through text. I have a ton of pictures if you are looking for anything specific just ask Kyle 542 350 0596 Last edited by oneshotkyle; 11-15-2025 at 01:23 PM. |
| Bookmarks |
