Old 11-23-2025, 02:05 PM   #1
Paul Y
P0200 code and misfire on passenger bank LM7
Gents,
On struggle street and could do with some advice
LM7 swap into a 66 C10.
Stock PCM stock engine.
After my non start problems, solved with a crank position sensor. I have now developed a P0200 fault.
I have a Noid light which shows that there is signal to all of the passenger side injectors.
When I connect the harness back to the injector I can hear it clicking so is firing.
It sounds like the bank is firing but not as strongly as the driver’s side as when I disconnect an injector on the driver’s side there is a big drop in idle but on the passenger side it is very ‘light’.
Definitely has spark.
Fuel pressure is 58lb.
I would suspect injectors but not all on one bank.
Next check will be continuity from the pcm to the passenger side injectors.
Anything else I should’ve checking?
Appreciate your assistance.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
