Old 11-25-2025, 06:16 PM   #1
Toro
Toro's Avatar
Driver's seat parts/mechanism help
Does anyone know of a good thread that explains or shows how all of the parts should go together underneath the driver's seat for the spring/slide/release mechanism? My 72 has the original seats, but those parts (or what was left of them) were in a coffee can. I'm sure I'm missing something, just not sure what. Thanks.
Toro is offline   Reply With Quote
Old 11-26-2025, 08:35 AM   #2
dennislbrooks
dennislbrooks's Avatar
Re: Driver's seat parts/mechanism help
Don't know if any of these help.
https://www.lmctruck.com/interior/se...eat-components
https://67-72chevytrucks.com/vboard/...d.php?t=418802
ebay item 324482678170
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 11-26-2025, 11:05 AM   #3
hemi43
hemi43's Avatar
If you're stuck, I can take a picture of my seat mechanism.
FWIW, I have utility seats which will be somewhat different than the buckets.
hemi43 is offline   Reply With Quote
Old 11-26-2025, 11:22 AM   #4
Toro
Toro's Avatar
Thanks. I was referring to driver's bucket seat. Unless the mechanism is essentially the same as the bench?
Old 11-26-2025, 11:46 AM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Maybe this diagram will help?: https://67-72chevytrucks.com/vboard/...6&postcount=26
Old 11-26-2025, 12:22 PM   #6
Toro
Toro's Avatar
I wasn't searching the parts board, when I did I found these photos. It looks like there is a latching mechanism on each side with small springs, and then a large spring front to back, as well as a small spring for the handle/release. Some of these parts were being reproduced by a member, but no longer are. So at least it seems I know what I should be looking for, I guess now the question is does anyone make these now? I may have a few of the small parts but probably not all, and I know I don't have the large spring.
Old 11-27-2025, 10:07 AM   #7
hemi43
hemi43's Avatar
Not sure if you're capabable of accurately measuring those parts, but if you can I could make a DXF drawing of it and post it here. This way anyone that needs those parts can easily get one water or laser cut just about anywhere.
