Old 12-01-2025, 04:01 PM   #1
GearCat
1966 Suburban Saginaw shifter keeps popping out
I’m working on my friends 1966 suburban and the shifter keeps coming up and out of the transmission, anybody know of a retaining clip kit of some sort?there is a spring and a cap that is loose on top of it. My Google skills have gone down the drain
GearCat is offline   Reply With Quote
Old 12-01-2025, 06:45 PM   #2
Grounded63
Re: 1966 Suburban Saginaw shifter keeps popping out
Pretty sure that collar you're holding, needs to be pushed down and turned. One direction or the other to " lock " it down, iirc
Grounded63 is offline   Reply With Quote
Old 12-01-2025, 07:00 PM   #3
MusicMan70
MusicMan70's Avatar
From another thread here;
-push down on the collar and rotate it counter clockwise, collar will pop up then pull stick up and out.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-02-2025, 09:49 PM   #4
Short 3/4
Short 3/4's Avatar
There should be two pins inside the shifter tower that the cap hooks onto. Are yours missing?
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 12-03-2025, 06:46 PM   #5
GearCat
Ok thanks for the replies guys. Upon further inspection it looks like the two hooks on the cap are basically non existent. Idk if I can buy another one but maybe I’ll just drill this cap out a little bit to make some new hooks.
Old 12-03-2025, 11:10 PM   #6
AcampoDave
AcampoDave's Avatar
Looks like somebody did a little welding on the cap before too.
AcampoDave is offline   Reply With Quote
Old 12-04-2025, 02:01 PM   #7
Short 3/4
Short 3/4's Avatar
Looks like Novak can sell you exactly what you need, give them a call
292-SM420-T221
