Old 12-05-2025, 04:12 PM   #1
Toro
Toro's Avatar
Correct part # for K10 and Blazer tie rod end stock Dana 44
The replacement tie rod end that local part stores, RockAuto (and classic industries) show is correct for my 72 Blazer with stock Dana 44 is Moog ES375L and ES375R. However, the shank is too wide and the threaded portion doesn't go far enough through the knuckle to get the nut on. Comparing to the ones that were removed, the new one is also about 1/2 shorter. Has anyone else encountered this, or have a better part number? Or does the knuckle need to be reamed? Thanks for any help.
Toro is offline   Reply With Quote
