Old 12-08-2025, 03:39 PM   #1
c30
Active Member
c30's Avatar
67 and 77 4x4 spring mounts
I've bought this 67 k10 shortbed that is mounted on a 77 4x4 chassis.
This does not work well because of the kick up in the frame causes issues.
I've got a clean 71 c20 frame that I am going to shorten and convert the front to leaf springs.
I bought a 77 4x4 Blazer, mainly for the axles. I am thinking about using the entire front suspension from the Blazer. Springs, sway bar, power steering, tie rods etc.
I see no reason why I can't use the spring mounts off the 77 and mount them to the 71 frame. Or should I get the correct mounts for the 71?
Other than the issue with the parking brake cable dimple in the frame, what could go wrong here?
Any suggestions?
c30 is offline   Reply With Quote
