Old 12-10-2025, 11:50 PM   #1
prin
prin's Avatar
Carrier Bearing failure
So, I have had the carrier bearing mount to fail 3 times. It is breaking where the mount becomes the "T". Why is this happening????
prin is offline   Reply With Quote
Old 12-11-2025, 01:31 AM   #2
franken
Re: Carrier Bearing failure
Unbalanced?
Make sure the yoke ujoint is lined up right.
Just guesses...
franken is online now   Reply With Quote
Old 12-11-2025, 02:13 AM   #3
Bob B.
Check to make sure your slip joint is not bound up.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-11-2025, 12:22 PM   #4
Lee H
Lee H's Avatar
Did you adjust the pinion angles after lowering?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-11-2025, 05:04 PM   #5
HO455
HO455's Avatar
First off is your truck lowered (or lifted)?
Half ton with coils?
HD suspension listed on the SPID?
The link posted pertains to your problem. Read post 21 where I explain my theories on why these failures occur.
If you have more questions i will attempt to answer them.
https://67-72chevytrucks.com/vboard/...d.php?t=853630
RIP Bob Parks.
Old 12-11-2025, 11:42 PM   #6
1970Tex
1970Tex's Avatar
There should be some front to back adjustment where it mounts. Make sure your truck is at ride height when tightening these bolts. Too far either way will cause extra stress when the suspension is fully compressed, or extended.
1970 GMC C/K1500 SBC 350/TH350 3/4" drop. Original tuxedo black paint. 20" American torque thrust. Front disc brake/ 5 lug conversion.
1970Tex is offline   Reply With Quote
