Old 12-13-2025, 02:48 PM   #1
chris989
seat belt cover sleeve
Does anyone have a source for an EOM style sleeve. The original has a distinct twist and angle were it mounts.
All aftermarket are flat, straight and generic.
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 12-13-2025, 07:04 PM   #2
TKCR
TKCR's Avatar
Re: seat belt cover sleeve
Thanks,
Chris
Seatbelt Planet has them.
I’ll look in my stock pile, I may have one also. They can be a b!tch to pull the strap thru, especially at that curve at the bottom.
What color do you need? And what is the length?
Old 12-13-2025, 07:35 PM   #3
chris989
I have a suburban so the two fronts are 15 and the rear are 12,,I also am in need of the footman loop/retainer the holds the second row bench seat belts to the upright back so they do not fall down when the set is folded foreword.
I bought my webbing from SBPlanet. from the pictures theirs are universal. My OEM stuff has a distinct angle plus a twist.. I guess i could attempt to heat and twist it. With the custom console it need to rotate 90 to fit.
Chris
Old 12-13-2025, 08:20 PM   #4
TKCR
TKCR's Avatar
Chris
So these are not what you’re needing?
Old 12-13-2025, 10:19 PM   #5
chris989
I search their site, How did you find that? i did my year make etc.
Old 12-13-2025, 10:33 PM   #6
TKCR
TKCR's Avatar
Just look under accessories, and then sleeves. Don’t do a search for specific year and model. Some say they are for jeeps and s10’s. But they are all pretty much the same, maybe different lengths.
But I have used the Jeep sleeves for the blazer bucket seat sleeves. They are perfect for those.
