Old 12-15-2025, 01:52 AM   #1
D-n-Tyke
Help with lowering shock part numbers
Trying to order up shocks for a 1972 C10 we are lowering.
Truck is going to be built with:
- Front is 2.5" drop spindles with 1.0" drop springs.
- Rear is 4.0" drop springs
Shocks I am looking at
Front: CPP-4809G
Rear: CPP-4052G
Are these the correct shocks we need? Thanks.
D-n-Tyke is offline   Reply With Quote
Old 12-15-2025, 02:25 AM   #2
Richard
Re: Help with lowering shock part numbers
Simple answer. Stock length shocks will work fine in you application.
Richard
Old 12-15-2025, 01:52 PM   #3
SCOTI
SCOTI's Avatar
Front will be fine with a stock length shock. The 1" shorter coil is effectively the same as a 40yr old OE coil (as far as height) so the OE shock travel will accommodate that.
For the rear w/a 4" shorter coil, I would relocate & mod the brackets to run a stock length shock:
https://67-72chevytrucks.com/vboard/...d.php?t=437582
An alternative if you want to spend a little to improve shock functionality is to move the rear shocks outboard of the frame & improve the installed shock angle even more vs the previous DIY method above:
https://nolimit.net/store/Dropped-Sh...unts-p26244502
Always keep in mind, the shorter the shock, the less functionality there is within that reduced travel. You always want to run the longest stroke shock possible. So, if you can stick w/the OE specs, do it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2025, 06:08 PM   #4
MikeB
MikeB's Avatar
My truck has 3" drop coil springs in the rear. I used a shock relocation kit to allow more travel with stock-length KYB shocks. Been working fine for around 25 years. Got the kit from Early Classic Enterprises, a forerunner in the field of 67-72 suspension mods.
Something like this: https://www.jegs.com/i/JEGS/555/64350/10002/-1
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-15-2025, 07:39 PM   #5
SCOTI
SCOTI's Avatar
There 'ya go....
Basically 'new' pieces vs. reworking the originals for the OE location.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
